Hello from Gregg C Levine
Stan, about that comment, "actually--- no. ActiveX capability didn't
come along until VEE 6.".
Actually you're wrong. According to an eval copy of VEE 5.0 it can do
Active X controls. And I've run it. It's not as well defined as say
6.0 or the current family of 7.x but it could do it. It might not
return the advanced features that the individual wants however. The
individual should test this for himself. (Or herself.)
Gregg C Levine hansolofalcon@worldnet.att.net
"Remember the Force will be with you. Always." Obi-Wan Kenobi
> -----Original Message-----
> From: Stan Bischof [mailto:rsb@soco.agilent.com]
> Sent: Wednesday, November 09, 2005 8:01 PM
> To: VRF
> Cc: vrf@agilent.com
> Subject: Re: [vrf] RMChart ActiveX
> > Greetings,
> > Would it be possible to get an example using VEE version 5.01.
> actually--- no. ActiveX capability didn't come along
> until VEE 6.
> regards
> Stan
> You are currently subscribed to vrf as:
> To subscribe send a blank email to
"join-vrf@it.lists.it.agilent.com".
> If you need help with the mailing list send a message to "owner-
> Search the "unofficial vrf archive" at
"www.oswegosw.com/vrf_archive/".
> To: VRF
> Cc: vrf@agilent.com
> > Greetings,
> until VEE 6.
> regards
> Stan
To all: this really is a very nice chart. It's fast, small and flexible. I
have since confirmed that RMC_INFO is the problem, but that can be easily
cured by the author without a major hassle. Give this puppy a try. If you
like it, ask the author to modify RMC_INFO so it's IDispatch compatible &
offer to donate a few bucks. A little good will goes a long way!
-SHAWN-
> To: VRF
> Cc: vrf@agilent.com
> > Greetings,
> until VEE 6.
> regards
> Stan
