vrf Vee DLL Calling Convention problems ...
Question asked by VRFuser on Jun 19, 2001
just a couple of ideas on the dll problem.
- Is there ever a scenario in your program where by you may accidentally load
the same dll twice ? Say the program terminates before you unload/delete the dll
from memory and you then re-run it causing the dll to be loaded again ?
- I've found a pretty good, (and free !), tool for viewing process information
including loaded dlls etc. that may be of help to you in debugging your problem
; its called prcviewer and can be downloaded from
http://www.teamcti.com/pview/prcview.htm
Hope the above is of some use to you,
John Cahill
Test Engineer,
Lucent Technologies
