THANKS TO EVERYONE FOR THEIR HELP!
I made a .bat file as suggested below and it's now working
Alex
Sent: den 21 december 2005 19:35
To: Alexander Poulikakos (KI/EAB); 'VRF'
Subject: RE: [vrf] Is this doable? SendTo vee file
SUCCESS!
Yes - the easiest way to do this is indeed to employ a batch file. It's much simpler than trying to concoct quoted command lines with uncertain parsers. The argv parser has been around forever and we know exactly how it works.
Batch file:
AddEmptyLine.cmd (or .bat)
"c:Program FilesAgilentVEE Pro 7.5vee.exe" --ignore %1 -r "c:Documents and SettingsShawnMy DocumentsVEE Programs est.vee"
All on one line. So you see, Warren had it. It's just the brain-dead parser that was "scrouge"ing things up. Pop a shortcut to the batch file in SendTo, change it's icon to VEE's icon (so you can tell what it actually is) and the output of test.vee (from the commandLine function) is:
0: c:Program FilesAgilentVEE Pro 7.5vee.exe
1: --ignore
2: c:script56.chm <my right click file>
3: -r
4: c:Documents and SettingsShawnMy DocumentsVEE Programs est.vee
Things to keep in mind:
Windows associative app resolution = brain dead parser
Command interpreter = good parser
Spaces = bad, but good parser can handle it.
-SHAWN-
Alex
SUCCESS!
Batch file:
1: --ignore
3: -r
-SHAWN-
