It is the Version:
IO Libraries Suite 14.0 as you can see in the attached document in the last mail. But anyway it is the last software update and it doesnt work. Could it be an error from the previous used Vee version 6.2?
Mario Abraham
LASER COMPONENTS GmbH
Werner-von-Siemens-Str. 15
82140 Olching / Germany
Tel.: +49 8142 2864 69
Fax: +49 8142 2864 11
www.lasercomponents.com
Von: Les Hammer [mailto:Les.Hammer@CompleteTest.com]
Gesendet: Mittwoch, 9. Februar 2005 17:01
An: VRF
Betreff: [vrf] RE: Error in VEE 7.0 by using the find instruments
command
> Attached are the error messages.
>> ... Revision M.01.01.04 ... Is required
What version of VISA do you have?
Les Hammer
Partner
Complete Test
720 SW 14th St.
Loveland, CO. 80537
You are currently subscribed to vrf as: m.abraham@lasercomponents.com
Mario Abraham
An: VRF
command
Les Hammer
Partner
Complete Test
720 SW 14th St.
Loveland, CO. 80537
Mario Abraham
An: VRF
command
Les Hammer
Partner
Complete Test
720 SW 14th St.
Loveland, CO. 80537
