No problem with Win2k and VEE6
Bill Ossmann
Philips Ultrasound
e-mail: bill.ossmann@philips.com
I have just run Surf3DPlot.vee on an old NT4 (running Vee Pro 7) system and
that doesn't generate an error so it must just be XP and Win2k.
Dave Evanson
Characterisation Engineer
Sent: 10 February 2005 10:08
To: VRF
Subject: [vrf] Re: OpenGL version error
This also happens on my fully patched Win2K system, so it's not restricted
to XP.
Graeme Hilton
R&D Engineer
Schlumberger Sensa
Dave Evanson wrote the following:
> Systems: XP Pro SP2, Vee Pro 7.01.6721.0
> When running some MATLAB scripts that use surface plots (e.g. the example
> file Surf3DPlot.vee) I get a VEE Caution "Unrecognized OpenGL, defaulting
> 1.0" dialog box. Clicking OK allows the script to continue without any
> further problems. Is there any way to solve this, or at least prevent the
> dialog box from popping up?
> This happens on several different PCs with different graphics cards and
> drivers, but all running fully patched XP Pro SP2. I have full admin
rights
> on some of the PCs but not all.
> Regards,
> Dave Evanson
You are currently subscribed to vrf as: devanson@zetex.com
_________________________________________________________
Zetex Semiconductors - Solutions for an analog world.
To read the latest news from Zetex, read our ZetexPress newsletter
online at www.zetex.com/zetexpress
http://www.zetex.com
E-MAILS are susceptible to interference. You should not assume that
the contents originated from the sender or the Zetex Group or that they
have been accurately reproduced from their original form.
Zetex accepts no responsibility for information, errors or omissions in
this e-mail nor for its use or misuse nor for any act committed or
omitted in connection with this communication.
If in doubt, please verify the authenticity with the sender.
You are currently subscribed to vrf as: bill.ossmann@philips.com
Bill Ossmann
Philips Ultrasound
Dave Evanson
To: VRF
to XP.
Graeme Hilton
R&D Engineer
Schlumberger Sensa
rights
> Regards,
> Dave Evanson
