Hello VRF,
I am needing to build a test system requiring 40 COM (serial) ports using VEE 8.0 (with the 8.01 patch) and IO Libs 14.2.
If this will work, I plan to use five (05) - USB to 8 serial port converters in a Dell Optiplex 745 mini-tower computer running XP Pro. I have used one of these converters in the past with no problems. If this does not work, then I am forced into a matrix switch or something else equally bad.
However, I have experienced COM port limitations with VEE 5.01 and the "M" IO Libs. Even though the OS could recognize a larger number of ports, VEE 5.01 could not. I remember not being able to go beyond 13 ports.
Does anyone have experience using multiple USB-COM converters? If so, this upper limit number would be great information.
Thanks in advance,
George Tyrrell
TestDynamics LLC
Thornton, Colorado
Thanks in advance,
George Tyrrell
TestDynamics LLC
Thornton, Colorado
Thanks in advance,
George Tyrrell
TestDynamics LLC
Thornton, Colorado
