Hi Folks
Adam you got the fix.
But I must say I feel sooo stooopid,
Shawn it was that same problem in November but I totally forgot I had did
this, doh
But hey guys I did learn something new though home environment variables,
Cheeky Cheers
Amrik
From: KOHLER,ADAM (A-Scotland,ex1) [mailto:adam_kohler@agilent.com]
Sent: 16 June 2005 15:42
To: VRF
Subject: RE: [vrf] Runtme error
Maybe this is a bit simpler.
If you are running in the development environment then the path to the
IDs directory is
C:Program FilesAgilentVEE Pro 7.5Ids
But the run time environment is
C:Program FilesAgilentVEE Pro RunTime 7.0ids
But this is the gotcha
The hp661xx.cid is in the development directory but NOT in the runtime
one. If you look at the contents of both these directories the
development environment one has lots of *.cid files but the runtime one
has only 8!
I think they installation only puts a sample of the cid files in the
runtime directory as an example of where there should be.
Adam Kohler
South Queensferry Division
Agilent Technologies
Scotland
telnet 313 5327
e adam_kohler@agilent.com
> From: Shawn Fessenden [mailto:shawn@testech-ltd.com]
> Sent: Thursday June 2005 15:03
> To: PDL-LISTS,VRF (A-Lists,unix1)
> > When I run my program it gives the following error :
> If this is the same problem you had in November I'm afraid I can't
really
> think of any cause except maybe one: is there a HOME environment
variable
> defined? If there is it might be messing runtime up. Er, that actually
> sounds kinda weak!
> -SHAWN-
> You are currently subscribed to vrf as: adam_kohler@agilent.com
> If you need help with the mailing list send a message to "owner-
You are currently subscribed to vrf as: amrik.sekhon@geeplus.biz
No virus found in this incoming message.
Checked by AVG Anti-Virus.
Version: 7.0.323 / Virus Database: 267.7.3/15 - Release Date: 14/06/2005
No virus found in this outgoing message.
this, doh
Cheeky Cheers
Amrik
To: VRF
IDs directory is
has only 8!
Adam Kohler
Scotland
telnet 313 5327
really
variable
> sounds kinda weak!
> -SHAWN-
