> I am trying to find out what is the best way in which I can organise the
data
> into a format like (Byte1Byte2, Byte3Byte4) and then convert these bytes
into ASCII value ?
> I can currently organise this is (Byte1, Byte2) (Byte3, Byte4), but don't
know how to join these.
You could write the bytes to a file, then read back the file as ASCII.
Les Hammer
Partner
Complete Test
720 SW 14th St.
Loveland, CO. 80537
Les.Hammer@CompleteTest.com
I am currently reading data from A direct I/O, and am reading the data using
the Binary Byte format.
This causes the data to be expressed in decimal foirmat.
data into a format like
(Byte1Byte2, Byte3Byte4) and then convert these bytes into ASCII value ?
If theres anyone who could shed any light on this, it would be appriciated.
Afsihcalledbill@hotmail.com
Liverpool UK
