"Strutt, Michael" <MStrutt@tycoelectronics.com> wrote:
> Shawn is right if you set your home variable to
> C:Program FilesAgilentVEE Pro 7.0
> or whatever the version and location of your files it should work ok.
I have to disagree here-- user data should NEVER be placed
in a application installation directory. $HOME is for
_user_ data and should not point to C:Program FilesAgilentVEE Pro 7.0
VEE doesn't use $HOME to look for ID's anyhow- it looks
in the application install directory.
Stan
Stan
If this is the same problem you had in November I'm afraid I can't really
think of any cause except maybe one: is there a HOME environment variable
defined? If there is it might be messing runtime up. Er, that actually
sounds kinda weak!
-SHAWN-
