Clif,
You might want to look as JSPayne and see if you could use that instead. It is very user friendly and easy to use.
http://www.jspayne.com/io/io.html
Mark
_____
Subject: [vrf] WIN98 DLL (Parallel Port)
Date: Tue, 15 Jul 2008 20:19:12 -0700
To: vrf@agilent.com
All,
We recently upgraded our test systems from WIN98 to XP. The test program loads a custom WIN98 parallel port DLL to communicate with the device under test for configuration purposes. When making a call to the DLL VEE reports a system error. We thought this could possibly be addressed through the utilization of the inpout32.dll, but unfortunately this hasn’t helped.
I suspect the solution is to re-write the DLL or develop a wrapper. Appreciate your recommendations on what would be the simplest approach.
Respectfully,
Clif
You are currently subscribed to vrf as: modelshopcnc@hotmail.com
_____
Making the world a better place one message at a time. HYPERLINK "http://www.imtalkathon.com/?source=EML_WLH_Talkathon_BetterPlace"Check out the i’m Talkathon.
You are currently subscribed to vrf as: hua_jing@agilent.com
Mark
_____
To: vrf@agilent.com
All,
Respectfully,
Clif
_____
Respectfully,
Clif
