Dennis,
The Visual Basic for Applications (VBA) code in Excel Macros would be Range(“A1”).Value which returns the value of the cell A1.
Now, from memory you can use VBA script in VEE to achieve the same result, I think it might be xlApp.Range(“A1”).Value in a VEE Formula Box.
Hope this helps.
Cheers,
Gary
Gary Voltz
SASTO4
Test Equipment and Maintenance and Calibration Centre
Facilities Management Services
Technology and Asset Services
Airservices Australia
E-mail: gary.voltz@airservicesaustralia.com
_____
Ph 1300 301 120 (within Australia)
Ph +61 7 3866 3382 (outside Australia)
Fax +61 7 3866 3531
HYPERLINK "http://www.airservicesaustralia.com/"www.airservicesaustralia.com
CAUTION: This e-mail is confidential. If you are not the intended
recipient, you must not disclose or use the information contained
in it. If you have received this e-mail in error, please tell us
immediately by return e-mail and delete the document.
Airservices Australia does not represent, warrant or guarantee
that the integrity of this communication is free of errors, virus
or interference.
_____
From: Byk Dennis-EDB023 [mailto:EDB023@motorola.com]
Sent: Saturday, 4 August 2007 4:36 AM
To: VRF
Subject: [vrf] Reading function results from excel
I have a cell in excel that uses the bin2hex and concatenate functions to assemble a string. When I try to read in the result of the formula, a text string, into VEE 8.0 I do not get the text that I see when I look at an excel sheet. When I use "Get data from cells" I receive the formula as a text string, not the formula result. When I use "Get Data-Evaluate Cell Formula" VEE returns a number (-2146826273) rather than the expected string. Is VEE treating the string as the numerical representation of each ASCII character? I need to find a way to import the formula result which is non-numeric. Is there a way around this?
Thank you for any helpful suggestions you may have.
Dennis
You are currently subscribed to vrf as: gary.voltz@airservicesaustralia.com
You are currently subscribed to vrf as: hua_jing@agilent.com
Hope this helps.
Cheers,
Gary
Gary Voltz
SASTO4
_____
Fax +61 7 3866 3531
or interference.
_____
To: VRF
Dennis
Dennis
