Check out this link...
http://www.sonic.net/~doomer/WhitePapers/SecureVee/SecureVee.html
- doomer
> It's possible to run vee programs in fullscreen mode? (and widthout resize
> possibility)?
> It's possible to catch the exit event from a VEE program?
> Greetings.
> Pablo C. Vergara Castro.
> Departamento de informtica.
> TQR-Software
> Tlfno.: (+34) 986 11 46 40
> Fax: (+34) 986 11 46 50
> You are currently subscribed to vrf as: doomer@soco.agilent.com
> If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".
- doomer
> possibility)?
> Greetings.
> TQR-Software
You could try this activeX: http://www.sirocco.force9.co.uk/#CRCOcx
Hope this helps,
Nelson
Bojan Stajcar wrote:
>Hi,
>I need to generate CRC_16, to be able to control the instrument via Direct
>IO.
>It seems that the formula is not available within VEE...
>Could anyone help me to do it?
>Thank you in advance and my best regards,
>Bojan
>You are currently subscribed to vrf as: nmambre@seebeck.com.ve
