*edited
I’ve used “*WAI” a lot recently to great effect.
The trick is in the sequencing. First you have to turn off continuous Triggering, with the devices I’m using that is “INIT:CONT OFF”, then send your “INIT:IMM;*WAI” or ”INIT:IMM” then “*WAI”.
Gary Voltz
SASTO4
Test Equipment and Maintenance and Calibration Centre
Facilities Management Services
Technology and Asset Services
Airservices Australia
E-mail: gary.voltz@airservicesaustralia.com
_____
Ph 1300 301 120 (within Australia)
Ph +61 7 3866 3382 (outside Australia)
Fax +61 7 3866 3531
HYPERLINK "http://www.airservicesaustralia.com/"www.airservicesaustralia.com
CAUTION: This e-mail is confidential. If you are not the intended
recipient, you must not disclose or use the information contained
in it. If you have received this e-mail in error, please tell us
immediately by return e-mail and delete the document.
Airservices Australia does not represent, warrant or guarantee
that the integrity of this communication is free of errors, virus
or interference.
_____
Sent: Tuesday, 21 August 2007 4:06 AM
To: VRF
Cc: VRF
Subject: [vrf] Timing Problem with Init:Imm
I am trying to use VBA and GPIB commands, however I am having a problem with timing. I am first hitting Run SGL (single) and then "init:imm" and requesting Fetch EVM and reading it, however the timing for the init:imm takes 3 seconds for it to load and my program debugs. I tried the *WAI function after I placed the Init:Imm, however it did not work. I also tried the *OPC? command, however when I read in OpcOk$, it also came up as "1" and my evm value read in as " ". (quotation with nothing in the middle). Any suggestions and comments other than putting in a manual delay. I want Rhode and Schwarz to tell me when the EVM value is ready to read, other than it reading in " " (blank), if it is not ready for it to wait for it to be ready, and then read in the value.
Thanks
_____
Be a better Heartthrob. HYPERLINK "http://us.rd.yahoo.com/evt=48255/*http:/answers.yahoo.com/dir/_ylc=X3oDMTI5MGx2aThyBF9TAzIxMTU1MDAzNTIEX3MDMzk2NTQ1MTAzBHNlYwNCQUJwaWxsYXJfTklfMzYwBHNsawNQcm9kdWN0X3F1ZXN0aW9uX3BhZ2U-?link=list&sid=396545433"Get better relationship answers from someone who knows.
Yahoo! Answers - Check it out. --- You are currently subscribed to vrf as: gary.voltz@airservicesaustralia.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "http://www.vrfarchive.com/vrf_archive". Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
You are currently subscribed to vrf as: hua_jing@agilent.com
Gary Voltz
SASTO4
_____
Fax +61 7 3866 3531
or interference.
_____
To: VRF
Cc: VRF
Thanks
_____
How did you manage to do that?
Is VEE in a working state? I thought it is not possible to have v7.5 installed without IO libs already there...
BR
Yiannis
From: Harwood, Shaun [mailto:shaun.harwood@siemens.com]
Sent: 21 August 2007 17:42
To: VRF
Subject: RE: [vrf] VEE 7.5 Vista Support
Hello all
I managed to install and run 7.5 on vista but the IO libs 14 didn't work. I was under the impression 7.5 would be ok with the version 15 library release. Perhaps Agilent could clarify?. This I imagine is all part of the vista 'wow' experience as I constantly find myself saying "wow - another development tool that doesn't work" - Don't even get me going on visual studio...
Best regards
Shaun H
You are currently subscribed to vrf as: Ioannis.Tolios@adckrone.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com"
