vrf communicate with a SPS
Question asked by VRFuser on Feb 3, 2005
Hello, Siegfried
In the past Ive done a couple of applications just like you descibe.
Ive used the serial port, with a defined code table.
Normaly you have a couple of std movements/tasks you want to control.
Make the SPS code for them and let the SPS check for code on the serial port.
It is essential to make a detailed handshaking protocol.
The emergency button should connect direct to the SPS.
Hlsningar/Regards
Ulf Jakobsson
Production Quality
AMC Centurion AB
P.O.Box 500, S-184 24  kersberga, Sweden
Tel direct +46 8 555 724 25
e-mail:ulf.jakobsson@centurion.se
www.centurion.com
[mailto:siegfried.lauble@junghans-fwt.de]
Sent: den 3 februari 2005 10:45
To: VRF
Subject: [vrf] communicate with a SPS
Hello together,
I'am looking for a solution for a very special problem. I'am planning an
automatic test-machine controlled by a SPS (Simatic S7).
The electronic measurements are accomplished with VEE.
I would like to communicate directly with the SPS. (Use VEE as HMI
interface and testsoftware)
Does someone have experience within this range? I
best regards
Siegfried  Lauble
Junghans Feinwerktechnik
Unterbergenweg 10
78655 Dunningen
Tel.: 07402/181-96
Fax: 07402/181-32
English : autocreated E-Mail Appendix: The content of this E-Mail is not
legally binding upon Junghans, even though the certified electronic
signature technique may point to the writer of the E-Mail. If this E-Mail
was transmitted to you by error, then please inform us accordingly (+49
7422 18-1).  In such case you are requested to erase the message. Any
unauthorized reproduction, disclosure, modification, distribution and/or
publication of such E-Mail message is strictly prohibited.
Deutsch : automatisch erzeugter E-Mail Anhang: In Verbindung mit
Kostenuebernahmen, Lieferungen, Angeboten und Vertraegen ist der Inhalt
dieses E-Mails fuer Junghans rechtlich nicht verbindlich, auch wenn die
Anwendung des elektronischen, zertifizierten Signaturverfahrens den
Ersteller des E-Mails nachweist. Informieren Sie uns bitte, wenn Sie
dieses E-Mail faelschlicherweise erhalten haben (+49 7422 18-1).  Bitte
lschen Sie in diesem Fall die Nachricht. Jede unerlaubte Form der
Reproduktion, Bekanntgabe, Aenderung, Verteilung und/oder Publikation
dieser E-Mail ist strengstens verboten.
>>>>>>>>>> This mail and its attachments are virus-checked! <<<<<<<<<<
You are currently subscribed to vrf as: Ulf.Jakobsson@centurion.se
