vrf Value in array
Question asked by arief12 on May 2, 2005
Hallo all
Thank you all for the solution it's works.
I appreciate it very much
Regards
Arie Fainbrun
Direct:  972-(0)524523459
Office: 972-(0)88577304
Fax:    972-(0)88572658
From: Stan Bischof (Richard S) [mailto:rsb@soco.agilent.com]
Sent: Monday, May 02, 2005 5:24 PM
To: VRF
Cc: vrf@agilent.com
Subject: RE[2]: [vrf] Value in array
Bill Ossmann <bill.ossmann@philips.com> wrote:
> In other words . . .
> x[minindex(abs(x-testval))]
> gives the element of x that is closest to testval.
Or if you want to interpolate you can resample using the build arbitrary
waveform then use the min index formula.
For example the below will interpolate to a couple of decimal points
array ------------------------
      |                        build arbitrary waveform  ----
      |-- formula          ---                              |
          100(totSize(a)-1))                               minX(abs(a+1)
regards
Stan
Stan Bischof  Agilent Technologies  707-577-3994  stan_bischof@agilent.com
You are currently subscribed to vrf as: arief12@netvision.net.il To
subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".
