I found out that Matlab scrips in VEE-Lab don't function in Windows Vista.
Is there any support?
Best regards,
Daniel Oldenziel
_______________________________
HYNATEC
Dr. Daniel Oldenziel
Les Allées 19
CH-2300 La Chaux-de-Fonds
Tel : (+) 41 (0) 32 913 3860
Fax : (+) 41 (0) 32 913 3858
GSM : (+) 41 (0) 78 608 2542
e-mail : mailto:oldenziel@hynatec.com
web : http://www.hynatec.com/
This transmission contains information which may be confidential and which may also be privileged. It is intended for the named addressee only. Unless you are the named addressee, or authorised to receive it on behalf of the addressee you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please contact the sender. Thank you for your cooperation.
You are currently subscribed to vrf as: hua_jing@agilent.com
Best regards,
Daniel Oldenziel
HYNATEC
Les Allées 19
