vrf AW: Changing line color of x-y plot - Enumeration
Question asked by willie.kiely on Jan 30, 2005
One other handy number.......(at least I thought so) is the Default panel
color (light blue grey).
The RGB values for this are
R-198
G-211
B-222
Can be useful when trying to integrate ActiveX displays or indicators onto a
VEE panel, without having a border.
Sent: 29 January 2005 08:50
To: VRF
Subject: [vrf] RE: AW: Changing line color of x-y plot - Enumeration
values
OK, in case the horse wasn't quite dead enough...
Here's a complete table including VEE6 & VEE7. VEE7 data
was obtained by setting the values or a graph using control
inputs, then looking at the results in the Properties area.
The descriptions are their words, not mine. As Shawn pointed
out, a DashDot LineType appears like a LongDash ShortDash,
rather than a true Dash Dot.
VEE7 also changed some terminology on us, by using "Color",
"LineStyle", and "PointStyle" in the Properties area, but
still requiring the older "Pen", "LineType", and "PointType"
when submitting these values to a graph via record input.
IMO, they just added another layer of confusion to an already
under-documented feature of VEE. As some of you may have found
out for yourselves, the info below is nowhere to be found in
the VEE6 or VEE7 online help files.
(Best viewed with a fixed font.)
VEE6    Pen              LineType          PointType
      (Color)          (LineStyle)       (PointStyle)
0 -   Black             None              Point
1 -   White             Solid             Diamond
2 -   Red               Point             Box
3 -   Green             Dot               X
4 -   Yellow            Dash              Plus
5 -   Blue              Dash              Spike
6 -   Magenta           DashDot           Fill
7 -   Cyan              Dash              Triangle
8 -   DarkYellow        DashDotDot        Table
9 -   DarkGray          Dot               Star
10 -   Black             [Error]           Octagon
11 -   Black             [Error]           UpArrow
12 -   Black             [Error]           Splat
13 -   Black             [Error]           I
14 -   Black             [Error]           Y
15 -   Black             [Error]           Xbox
16 -   Black             [Error]           Z
17 -   Black             [Error]           Hourglass
18 -   Black             [Error]           [Error]
19 -   Black             [Error]           [Error]
20 -   Black             [Error]           [Error]
(Same results for all integers 18 and higher.)
VEE7    Pen              LineType          PointType
0 -   Black             Unknown*          Point
2 -   Red               Point             Box
3 -   Green             Dot               X
5 -   Blue              Dash              Spike
10 -   Black             Solid             Octagon
11 -   Black             Unknown*          UpArrow
12 -   Black             Solid             Splat
13 -   Black             Point             I
14 -   Black             Dot               Y
15 -   Black             Dash              Xbox
16 -   Black             DashDot           Z
17 -   Black             DashDotDot        Hourglass
18 -   Black             Solid             [Error]
19 -   Black             Solid             [Error]
20 -   Black             Solid             [Error]
* "Unknown" LineType is displayed without error as "None".
Sure hope this helps somebody out there. At least it will be
in Shawn's archive for future generations.
Cheers,
Mike Groves
You are currently subscribed to vrf as: Willie.Kiely@bourns.com
