Dear all,
I have a very strange error on a VEE file when run under WIN XP SP2.
The problem happens at the end of run, when I chick everywhere on the
screen. The Error is : Messagge 'deactivate' sent to freed object.
I saved the file with a different name, but it is still there.
If I start again the same file it starts and makes everthing it has to,
but gives this error at the end.
I only have a clue, not sure it is related. I use a dataset to start the
programm. Sometime I change the file, and the error seems to be related
to this change.
But... I tried to use it on Win 2k, and it works without problems.
I use VEE 6.03
Thanks for any help
Gianfranco Durin
Istituto Elettrotecnico Nazionale Galileo Ferraris
Strada delle Cacce, 91 - 10135 Torino Italy
tel: ++39 011 3919839 fax: ++39 011 3919834
Personal home page: http://www.ien.it/~durin/
IEN home pag: http://www.ien.it/
Per favore non mandatemi allegati in Word o PowerPoint, Grazie!
Si veda http://www.fsf.org/philosophy/no-word-a ... ts.it.html
Please do not send me Word or Powerpoint attachments, thanks!
See: http://www.fsf.org/philosophy/no-word-attachments.html
You are currently subscribed to vrf as: unknown subst tag argument: 'emailaddr'
to this change.
I use VEE 6.03
Thanks for any help
Gianfranco Durin
