Oh! No problemo. Stick a router in front of the computer and forward port 23 outside to port 12345 inside. Just don't run an Italk Chat System client/server inside the wall.
-SHAWN-
> -----Original Message-----
> From: Kjeld Alexander [mailto:k.alexander@get2net.dk]
> Sent: Monday, July 21, 2008 3:47 PM
> To: VRF
> Subject: Fw: [vrf] Fw: Telnet
> Another way of illustrating my needs, when it comes to telnet com.
> I want to estabilish a "gateway". I understand that vee do not go
> below port 1024.
> I am thinking, non vee sw (.dll) that bind 23 and connect to port
> 12345 bind by vee. Non vee sw rx data on port 23 and tx received data
> on port 12345, and Non vee sw rx data on port 12345 and tx data on
> port 23.
> Could this work and are it possible on win xp?
> I understand that telnet understanding are needed when/if gateway are
> estabilished
> BR
> Kjeld Alexander
> ----- Original Message -----
> From: "Shawn Fessenden" <shawn@vrfarchive.com>
> To: "VRF" <vrf@agilent.com>
> Sent: Thursday, July 10, 2008 8:31 PM
> Subject: RE: [vrf] Fw: Telnet
> >> Will this help?
> > Well it proves Windows has an inetd
> > I think the object here is to monitor traffic to identify the client
> > transmissions necessary to initiate a Telnet session to a
> specific server.
> > If that's incorrect then I've been laboring under the wrong
> impression.
> > At any rate, if you want to use Telnet to send commands to
> a computer it's
> > one of the easiest ways to do so. Rather than implement a
> full client, all
> > you really need to do is capture the conversation between
> client & server
> > up
> > to the point you get a prompt and just emulate that in VEE.
> > The problem is you can't listen in on a port once a connection is
> > established. That's why I said use Wireshark.
> > You can easily make a connection & look at the data coming
> back from the
> > server, but in the case of Telnet that doesn't really help
> a whole lot as
> > the protocol is strictly binary - and relatively complex
> when compared to
> > protocols like mail & news. Once you establish a session
> it's a piece of
> > cake but until then you must support the negotiation sequence.
> > -SHAWN-
> > You are currently subscribed to vrf as: k.alexander@get2net.dk To
> > subscribe please send an email to:
> "vrf-request@lists.it.agilent.com"
> > with the word subscribe in the message body.
> > To unsubscribe send a blank email to
> > To send messages to this mailing list, email "vrf@agilent.com".
> > If you need help with the mailing list send a message to
> > "owner-vrf@it.lists.it.agilent.com".
> > Search the "unofficial vrf archive" at
> > "http://www.vrfarchive.com/vrf_archive".
> > Search the Agilent vrf archive at
> "http://vee.engineering.agilent.com".
> You are currently subscribed to vrf as: shawn@vrfarchive.com To
> "vrf-request@lists.it.agilent.com" with the word subscribe in the
> message body.
-SHAWN-
> To: VRF
> below port 1024.
> port 23.
> estabilished
> BR
> Kjeld Alexander
> >> Will this help?
> specific server.
> impression.
> a computer it's
> full client, all
> client & server
> > up
> back from the
> a whole lot as
> when compared to
> it's a piece of
> > -SHAWN-
> message body.
I still need to overcome rx data on port 23...I can not rx data on that port so is there someone (Shawn) that have a solution to that. ( just plain to/from sockets)
BR
Kjeld Alexander
From: HYPERLINK "mailto:k.alexander@get2net.dk"Kjeld Alexander
To: HYPERLINK "mailto:vrf@agilent.com"vrf@agilent.com
Sent: Tuesday, July 08, 2008 3:13 PM
Subject: Telnet
I try to log incoming on port 23 by binding that port in one vee app.
In another vee app on the same PC I try to connect to port 127.0.0.1:23
I have a suspicion that the OS/SW are in the way, since it works on port 5500.
Can anyone out there shead some light on this problem
BR
Kjeld Alexander
