<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"><HTML><HEAD><META http-equiv=Content-Type content="text/html; charset=iso-8859-1"><META content="MSHTML 6.00.2800.1479" name=GENERATOR><STYLE></STYLE></HEAD><BODY bgColor=#ffffff><DIV><FONT face=Arial size=2>Hello Ivan</FONT></DIV><DIV><FONT face=Arial size=2></FONT> </DIV><DIV><FONT face=Arial size=2>We had a kind of similar problem. In our application we generate VEE files which contain variable declarations. We import this VEE file to declare variables.</FONT></DIV><DIV><FONT face=Arial size=2></FONT> </DIV><DIV><FONT face=Arial size=2>At some point a file was corrupted and the text "UInt8" turned into "UInu8". We never found out how this happened. It only happened once and we use this method all the time. We are certain that it was not due to a bug in our code. </FONT></DIV><DIV><FONT face=Arial size=2></FONT> </DIV><DIV><FONT face=Arial size=2>The VEE files are generated once per software revision, not generated on the fly for each use. I don't see how VEE should change the contents of an imported VEE library and I doubt Windoze would have corrupted the file, but who knows eh?</FONT></DIV><DIV><FONT face=Arial size=2></FONT> </DIV><DIV><FONT face=Arial size=2>This info is probably useless, but, just letting you know.</FONT></DIV><DIV><FONT face=Arial size=2></FONT> </DIV><DIV><FONT face=Arial size=2>Best regards</FONT></DIV><DIV><FONT face=Arial size=2></FONT> </DIV><DIV><FONT face=Arial size=2></FONT> </DIV><DIV><FONT face=Arial size=2>Andrew Fudge</FONT></DIV><DIV><FONT face=Arial size=2>Genesys IBS</FONT></DIV><DIV><FONT face=Arial size=2>Wales, UK</FONT></DIV><DIV><FONT face=Arial size=2></FONT> </DIV><BLOCKQUOTE style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px"> <DIV style="FONT: 10pt arial">----- Original Message ----- </DIV> <DIV style="BACKGROUND: #e4e4e4; FONT: 10pt arial; font-color: black"><B>From:</B> <A title=ivan.edwards@irisys.co.uk href="mailto:ivan.edwards@irisys.co.uk">Ivan Edwards</A> </DIV> <DIV style="FONT: 10pt arial"><B>To:</B> <A title=vrf@agilent.com href="mailto:vrf@agilent.com">VRF</A> </DIV> <DIV style="FONT: 10pt arial"><B>Sent:</B> Thursday, January 13, 2005 10:24 AM</DIV> <DIV style="FONT: 10pt arial"><B>Subject:</B> [vrf] spelling change</DIV> <DIV><FONT face=Arial size=2></FONT><BR></DIV> <DIV><FONT face=Arial size=2><SPAN class=809331510-13012005>I have been running a VEE6 .vxe program on two PCs successfully for the past month. The program runs through a test routine every 15 minutes all day long. Every run through the program takes it through a UserFunction which gets a variable globalWindow at two points. Today I have had the attached error thrown up which refers to a globalWmndow not found. I have checked the .vee program and there is no spelling mistake. After re-booting all is well again. Does anyone know what's happening and how can I stop it?</SPAN></FONT></DIV> <DIV><FONT face=Arial size=2><SPAN class=809331510-13012005></SPAN></FONT> </DIV> <DIV><FONT face=Arial size=2><SPAN class=809331510-13012005></SPAN></FONT> </DIV> <P><FONT face="Courier New" size=2>Ivan Edwards</FONT> </P> <P></P><FONT face="Courier New" size=2></FONT> <HR> <P></P>---<BR>You are currently subscribed to vrf as: AndrewF@genesysibs.com<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".<BR></BLOCKQUOTE>---<BR>You are currently subscribed to vrf as: rsb@soco.agilent.com<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".</BODY></HTML>
i want to create a bargraph display (like mschart) who gets its values
from a 2D array.
The x axis values from column 1, the y axis value from column 2.
The chart should be embedded in the panel of a user function to display
additional information.
I want to print the user function panel as a test report on a printer.
Questions:
The chart always shows the line number of the array as x axis values, how
can i use the values from column 1 as x value ?
How can i fit the panel of the user funktion to the page of my printer
(centered) ?
best regards
Siegfried Lauble
Junghans Feinwerktechnik
Unterbergenweg 10
78655 Dunningen
Tel.: 07402/181-96
Fax: 07402/181-32
mailto:siegfried.lauble@junghans-fwt.de
English : autocreated E-Mail Appendix: The content of this E-Mail is not
legally binding upon Junghans, even though the certified electronic
signature technique may point to the writer of the E-Mail. If this E-Mail
was transmitted to you by error, then please inform us accordingly (+49
7422 18-1). In such case you are requested to erase the message. Any
unauthorized reproduction, disclosure, modification, distribution and/or
publication of such E-Mail message is strictly prohibited.
Deutsch : automatisch erzeugter E-Mail Anhang: In Verbindung mit
Kostenuebernahmen, Lieferungen, Angeboten und Vertraegen ist der Inhalt
dieses E-Mails fuer Junghans rechtlich nicht verbindlich, auch wenn die
Anwendung des elektronischen, zertifizierten Signaturverfahrens den
Ersteller des E-Mails nachweist. Informieren Sie uns bitte, wenn Sie
dieses E-Mail faelschlicherweise erhalten haben (+49 7422 18-1). Bitte
lschen Sie in diesem Fall die Nachricht. Jede unerlaubte Form der
Reproduktion, Bekanntgabe, Aenderung, Verteilung und/oder Publikation
dieser E-Mail ist strengstens verboten.
>>>>>>>>>> This mail and its attachments are virus-checked! <<<<<<<<<<
