vrf VRF Serial Port supported by the .NET Framework 2.0 (VEE Pro 8.0)
Question asked by VRFuser on Jul 30, 2007
It depends upon what commands you send before.  If you send a Sing command, it means "single sweep the analyzer and hold it after the sweep so that the data doesn't change before I read it out".  To start sweeping again, send the CONT command.
If you use the fast outputs (Outpdatf, outpforf), rather than the regular (outpdata, outpform), then it instructs the analyzer to "hold the data acquisition until the GP-IB command completes)," ; you must read out all the bytes before it will sweep again, or send a clear to the analyzer address.
Joel
  _____
From: Bharadvaj Podduturi [mailto:vaj_sage@yahoo.com]
Sent: Monday, July 30, 2007 4:41 PM
To: VRF
Subject: [vrf] VNA8753 (external control inputs)
I am programming 8753E via GPIB in order to extract some data. The problem is as soon as I run the vee program to extract the data, I get the data but it freezes the display screen of the analyzer. I would like to look at the data on the Analyzer screen before I save it. Is there a way to stop the Analyzer from freezing up like this.
Probably I can include an additional instruction at the end of the vee program which tells the Analyzer to free up and act normally? I just don't know what that instruction would be...
Can anyone guide me...
Bharadvaj
  _____
5, 50, 500, 5000. Store N number of mails in your inbox. HYPERLINK "http://in.rd.yahoo.com/tagline_mail_4/*http://help.yahoo.com/l/in/yahoo/mail/yahoomail/tools/tools-08.html/"Click here. --- You are currently subscribed to vrf as: joel_dunsmore@agilent.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "http://www.vrfarchive.com/vrf_archive". Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
You are currently subscribed to vrf as: hua_jing@agilent.com
