One of the really nasty tricks you can play on people with VEE is to put a Stop object in their program -- usually way off to the side. When you use the runtime version, it operates just like you described. Not that I would ever do anything like that of course ...
-Matt Bradley
-Matt Bradley
I have just written a VEE 6 program where I am charting a voltage signal and
saving the data to a file once every second. The VEE program works without
any problem. I created a runtime version and now whenever I try to run the
runtime version, it appears to open and then immediately close. I cannot get
it to run. When I open the VEE program again, it will work fine, but the
runtime version won't. Can someone give me some suggestions on what I am
possibly doing (or have done) wrong?
Please let me know if there is any other information I can provide that
would be helpful.
Thank you very much.
Milan
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
Este mensaje (incluyendo los archivos adjuntos) esta dirigido solo al receptor senalado y puede contener informacion de caracter privilegiada, privada o confidencial. Si usted no es el receptor senalado o bien ha recibido este mensaje por error, por favor notifique inmediatamente al remitente y elimine el mensaje original. Cualquier otro uso de este mensaje de correo electronico esta prohibido.
