That is possible.
Take the binary, read in as binary and make it as constant. Then save the constant to a location you want ( on different pc .s) and name it correctly..same as you want to read in as .bmp....
_____
Von: Doug Parrish [mailto:doug.parrish@comtechpst.com]
Gesendet: Freitag, 10. August 2007 15:04
An: VRF
Betreff: RE: [vrf] Run time prob.
I Had the same problem. VEE is looking for the picture on the other machine in the same location….
C:Some Folderyourbitmap.bmp
You should copy your bitmap to the same location on the other PC and it will work fine. Unless anyone knows a way to embed the picture into the executable, that be better.
Doug Parrish
Test Engineer
Comtech PST
105 Baylis Rd
Melville, NY 11747
631.486.4126 (Direct)
631.777.8900 x 126
HYPERLINK "mailto:doug.parrish@comtechpst.com"doug.parrish@comtechpst.com
_____
From: Gavin Candy/Weymouth/EvoxRifa [mailto:gavincandy@kemet.com]
Sent: Friday, August 10, 2007 8:58 AM
To: VRF
Subject: [vrf] Run time prob.
Hi Vrf,
Firstly thanks for the reply on the array prob. It pointed me in the right direction.
I have one other problem, wondering if anybody else has experienced it.
When I create a Run time with VeePro 8.01 & 7.5, If I have a bitmap displayed it disappears when I install the run time on a separate machine.
Has anybody else experienced this problem.
Best Regards
Gavin.
--- You are currently subscribed to vrf as: doug.parrish@comtechpst.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "http://www.vrfarchive.com/vrf_archive". Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
You are currently subscribed to vrf as: Detlef.Baranski@pilkington.de
Der Inhalt dieser E-Mail (inkl. aller Anlagen) ist vertraulich und ausschließlich für den Adressaten bestimmt. Jede Art der Verbreitung, Nutzung oder Vervielfältigung ist untersagt. Sollten Sie diese E-Mail irrtümlich erhalten haben, informieren Sie bitte sofort den Absender und löschen die E-Mail.
Unternehmensangaben der Gesellschaften mit Sitz in Deutschland:
Pilkington Holding GmbH, Haydnstraße 19, 45884 Gelsenkirchen
Sitz: Gelsenkirchen, Amtsgericht Gelsenkirchen HRB 8997
Geschäftsführung: Jochen Settelmayer (Vorsitz), Dr. Clemens Miller, Thomas Kretschmann, Robert Hales
Vorsitzender des Aufsichtsrates: Dr. Axel Wiesener
Pilkington Deutschland AG, Haydnstraße 19, 45884 Gelsenkirchen
Sitz: Gelsenkirchen, Amtsgericht Gelsenkirchen HRB 2707
Vorstand: Dr. Clemens Miller, Jochen Settelmayer
Pilkington Automotive Deutschland GmbH, Otto-Seeling-Straße 7, 58455 Witten
Sitz: Witten, Amtsgericht Bochum HRB 8443
Geschäftsführung: Thomas Kretschmann
Vorsitzender des Aufsichtsrates: Jochen Settelmayer
Bauglasindustrie GmbH, Hüttenstraße 33, 66839 Schmelz / Saar
Sitz: Schmelz / Saar, Amtsgericht Saarbrücken HRB 52020
Geschäftsführung: Manfred Ebbers
You are currently subscribed to vrf as: hua_jing@agilent.com
_____
An: VRF
Doug Parrish
Test Engineer
Comtech PST
105 Baylis Rd
Melville, NY 11747
631.777.8900 x 126
_____
To: VRF
Hi Vrf,
Best Regards
Gavin.
That's what I expected, maybe inVeePro 8.5 they could fix this problem & embed the pictures into the run time.
Regards
Gavin.
"Baranski, Detlef" <Detlef.Baranski@pilkington.de>
10/08/2007 14:09
Please respond to
To
VRF <vrf@agilent.com>
cc
Subject
AW: [vrf] Run time prob.
That is possible.
_____
An: VRF
Doug Parrish
Test Engineer
Comtech PST
105 Baylis Rd
Melville, NY 11747
631.777.8900 x 126
_____
To: VRF
Hi Vrf,
Best Regards
Gavin.
You are currently subscribed to vrf as: gavincandy@kemet.com
--- You are currently subscribed to %%list.name%% as: %%emailaddr%% To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "http://www.vrfarchive.com/vrf_archive". Search the Agilent vrf archive at "http://vee.engineering.agilent.com".
