Thanks Kevin,
The problem is that it returns true for "3a" and false for "a3".
i.e. it takes 3 as a valid number when and ignores the 'a'
I want the function to return false for a number like 3a
I am only concerned with integers, so I do not want to interpret exponentials,
decimals or signs.
Cheers
John
> Kevin Dowsey <kdowsey@turnkey-solutions.com.au> wrote:
John
This will return true if there is any numeric data present.
At 11:28 AM 1/04/2005 +1000, you wrote:
>Hi,
>Just wondering if someone has implemented the equivalent of an isNumeric()
>function
>that checks a string to see if it contains a valid number, i.e it should
>return
>false if it contains non-numeric characters such as letters, etc.
>I know you can execute a loop and check each character individually, but I was
>looking for a slightly neater way.
>The 'From String" function does not return any errors if part of the string is
>non-numeric, and the asInt16() function only returns an error if the first
>character is non-numeric.
>Thanks
>John
>You are currently subscribed to vrf as: kdowsey@turnkey-solutions.com.au
>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".
>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".
>To send messages to this mailing list, email "vrf@agilent.com".
>If you need help with the mailing list send a message to
>"owner-vrf@it.lists.it.agilent.com".
decimals or signs.
Cheers
John
John
>Hi,
>function
>return
>Thanks
>John
System.Int16.Parse(Text value). It generates a VEE error if the text
contains any non-numeric characters. In the future (.NET 2.0), MS plans
to add TryParse methods that return a bool on failure instead of
throwing an error.
Keith
> -----Original Message-----
> From: jfreriks@optusnet.com.au [mailto:jfreriks@optusnet.com.au]
> Sent: Thursday, March 31, 2005 6:28 PM
> To: VRF
> Subject: [vrf] isNumeric function
> Hi,
isNumeric()
> function
should
> return
but I
> was
> string is
> first
> Thanks
> John
> You are currently subscribed to vrf as: keith_hill@agilent.com
