Okay, thanks...
From: Street, Andy M [mailto:andy.street@tycoelectronics.com]
Sent: Thursday, February 09, 2006 9:47 AM
To: VRF
Subject: RE: [vrf] VEE with Nat'l VISA
Hi Bill,
Â
I think you can (but I have never tried it for real!). Unless things have changed dramatically VEE's Direct I/O object puts a call into the SICL layer of the Agilent IO Libraries for GPIB. If the Agilent IO Libs are not installed/you are using the NI API, then VEE throws the call out to the NI488.DLL and hopes that it is there! For the serial port, VEE directs the call to the SICL layer. No SICL installed, no talking to the serial port, just the error message sicl32.dll not found...
Â
I think that you should be able to install the Agilent IO Libs side by side with your NI installation. Install Agilent VISA as secondary if you choose to install the VISA API. This 'should not' mess anything up. You might even want to try a custom install of the IO Libs and choose only to install the SICL API.
Â
That's the theory anyway...
Â
Good luck,
Â
Andy
Â
 _____ Â
From: Drago, William @NARDAEAST [mailto:William.Drago@L-3com.com]
Sent: Thursday, February 09, 2006 9:09 AM
To: VRF
Well, it was working until I tried use the serial port. If I'm just using GPIB everything is fine. When I tried a program that needs the serial port I get a SICL error message--"sicl32.dll not found."
Â
Is there a way to fix this? Can I install SICL without messing up all the National stuff?
Â
Bill
Sent: Tuesday, January 10, 2006 7:04 AM
To: VRF
All,
I installed VEE 7.0 runtime on my NI system yesterday and it worked. No problems at all.
Bill
> From: Baranski, Detlef [mailto:Detlef.Baranski@pilkington.de]
> Sent: Tuesday, January 10, 2006 6:54 AM
> To: 'Drago, William @NARDAEAST'; VRF
> Subject: AW: [vrf] VEE with Nat'l VISA
> It not that easy , sorry.
> Read the Manual. There are different things to take care
> dependent on the
> VEE Version you have.
> Since Vee 7 you need NI Visa lib 3 or higher , otherwise it
> is not working.
> With Iolib 14.1 and VEE 7.5 it should work without any big
> problems if Nilib
> is installed first. But there were some troubles also....
> So let us know if your attempt work.
> Best regards,
> detlef
> -----Ursprüngliche Nachricht-----
> Von: Drago, William @NARDAEAST [mailto:William.Drago@L-3com.com]
> Gesendet: Freitag, 6. Januar 2006 16:38
> An: VRF
> Betreff: RE: [vrf] VEE with Nat'l VISA
> Thanks, I'll give it a try.
> Â
> Bill
> From: BOCKSTAL,DANIEL (A-Belgium,ex1)
> [mailto:daniel_bockstal@agilent.com]
> Sent: Friday, January 06, 2006 8:45 AM
> To: VRF
> Hello Drago,
> VEE will play nicely with NI's VISA, no problem. You can have
> a side by side
> installation (NI VISA + Agilent VISA) on the same computer,
> but this is only
> required if you mix Agilent's and NI's hardware (an Agilent
> GPIB card and an
> NI GPIB card in the same PC)
> Â Best regards
> Daniel Bockstal
> Sent: Friday, January 06, 2006 2:23 PM
> To: VRF
> Subject: [vrf] VEE with Nat'l VISA
> All,
> Â
> I have a test system running LabWindows/CVI and TestStand. I want to
> install VEE runtime so I can use the equipment in that test
> system with some
> of my VEE programs.
> Â
> Will VEE play nice with the Nat'l VISA or does it need it's
> own? And, if it
> does need it's own, can the two VISAs co-exist?
> Â
> Thanks,
> Bill
> You are currently subscribed to vrf as: daniel_bockstal@agilent.com
> To subscribe send a blank email to
> "join-vrf@it.lists.it.agilent.com".
> Search the "unofficial vrf archive" at
> "www.oswegosw.com/vrf_archive/".
> You are currently subscribed to vrf as: William.Drago@l-3com.com
> This e-mail and subsequent attachments may contain
> information which is
> proprietary to L-3 Communications Corporation. The contents
> shall not be
> disclosed, copied, distributed or used unless authorized by L-3
> Communications Narda - East.
> You are currently subscribed to vrf as: Detlef.Baranski@pilkington.de
 This e-mail and subsequent attachments may contain information which is proprietary to L-3 Communications Corporation. The contents shall not be disclosed, copied, distributed or used unless authorized by L-3 Communications Narda - East.
You are currently subscribed to vrf as: andy.street@tycoelectronics.com
To subscribe send an email request to "owner-vrf@it.lists.it.agilent.com".
To: VRF
Hi Bill,
Â
Â
Â
Â
Good luck,
Â
Andy
Â
 _____ Â
To: VRF
Â
Â
Bill
To: VRF
All,
Bill
> dependent on the
> is not working.
> problems if Nilib
> Best regards,
> detlef
> An: VRF
> Â
> Bill
> To: VRF
> Hello Drago,
> a side by side
> but this is only
> GPIB card and an
> Â Best regards
> Daniel Bockstal
> To: VRF
> All,
> Â
> system with some
> of my VEE programs.
> Â
> own? And, if it
> Â
> Thanks,
> Bill
> shall not be
