> Shawn ?
Right on all points. Telnet is probably the easiest way to get an application going on a remote machine. WBEM connection to Task Manager is probably also an option if Telnet isn't secure enough.
Remote operation is another question entirely. Unless the app is built with client/server in mind then remote control through Remote Desktop, PCA, VNC, Goto My PC or similar is easy. The problem then becomes simultaneous access.
Ever watch two people trying to run the same PC?
Terminal server is another option. Clients start VEE on a Terminal Server session & so basically everybody gets their own private remote session, but the VEE application has to be built with that in mind too. Usually, multiple copies of VEE all doing the same thing on the same computer is a bad thing.
-SHAWN-
To subscribe send an email request to "owner-vrf@it.lists.it.agilent.com".
-SHAWN-
I am using VEE Pro 7.5, I have a program that I have developed
that I
have been trying to set up to allow other users from different
parts of the
company to execute. I have tried activating the Web server and
saving
the program as Runtime but I find that I can only observe
specific
portions of the program. Is there a method to allow excution of
this program via the web??
Dave
