AW: vrf Web access
Question asked by VRFuser on Feb 7, 2006
Oh yes, it is easier to install the runtime environment then and the program.vxe on each machine
By the way, the
http://www.applicationaccessserver.de/index_en.html
is a nice tool !
Perhaps Agilent may intergrate this in their next version as an answer for some remote control demand .....
Von: Shawn Fessenden [mailto:shawn@testech-ltd.com]
Gesendet: Dienstag, 7. Februar 2006 17:39
An: VRF
Betreff: RE: [vrf] Web access
> Shawn ?
Right on all points. Telnet is probably the easiest way to get an application going on a remote machine. WBEM connection to Task Manager is probably also an option if Telnet isn't secure enough.
Remote operation is another question entirely. Unless the app is built with client/server in mind then remote control through Remote Desktop, PCA, VNC, Goto My PC or similar is easy. The problem then becomes simultaneous access.
Ever watch two people trying to run the same PC?
Terminal server is another option. Clients start VEE on a Terminal Server session & so basically everybody gets their own private remote session, but the VEE application has to be built with that in mind too. Usually, multiple copies of VEE all doing the same thing on the same computer is a bad thing.
-SHAWN-
You are currently subscribed to vrf as: Detlef.Baranski@pilkington.de To subscribe send an email request to "owner-vrf@it.lists.it.agilent.com".
