Hi Qi,
Yes, I have tried a number of permutations...
For example:
Outputs=myFunc.Call(Inputs)
And also
Output=myFunc.Call()
For a function with no input arguments. I believe that if a function does not explicitly return a value, it will return a zero back to the calling system. Interestingly, Matlab, does not seem to be able to recognize this return - it always shows it as NaN. I have got nowhere with the Matlab ActX Client -> VEE Server in terms of being able to pass data back and forth to and from the functions. I have resorted to file reads/writes for passing of parameters. I believe that the problem lies with Matlab rather than Callable VEE as things are good in VBScript/VBA
Thanks for the suggestion
Andy
From: qi_gao@agilent.com [mailto:qi_gao@agilent.com]
Sent: Thursday, February 16, 2006 1:54 AM
To: Street, Andy M
Subject: RE: [vrf] Callable VEE Server
Andy,
Have you tried to do something like:
Outputs = myFunc.Call(Inputs)
This is because the second parameter is defined [in, out] in COM.
Qi
From: Street, Andy M [mailto:andy.street@tycoelectronics.com]
Sent: Tuesday, January 10, 2006 6:00 AM
To: VRF
Subject: [vrf] Callable VEE Server
Hello VRF,
I am trying to use the Callable VEE Server (using VEE Rev 7.51) with Matlab (Version 7) as the ActiveX client. I can instantiate the server, load a library (vee file), and determine the input and output argument properties etc. The one thing that I cannot do is call any of the functions.
In other words:
myFunc.Call(Inputs,Outputs)
throws an error in Matlab. Matlab/VEE complains about either the number of arguments (it says that the method can only accept one input
argument) or returns NaN when I am hoping it would return a number (user function has now inputs and is designed to return a Real64). I have been able to use VBScript and Excel VBA quite happily with the Callable VEE Server, so I think my VEE install is good. Does anyone know if you can work the VEE server successfully using Matlab as the ActiveX client and if so, what am I missing.
Thanks
Andy
You are currently subscribed to vrf as: qi_gao@agilent.com To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".
To subscribe send a blank email request to "join-vrf@lists.it.agilent.com".
For example:
And also
Andy
To: Street, Andy M
Andy,
Qi
To: VRF
Hello VRF,
In other words:
Thanks
Andy
functions.
In other words:
Thanks
Andy
