Hi Detlef,
I own the full version of both (6.01 and 7.51). I tried it also on a different computer, but there I get exactly the same error message.
Best Regards
Manfred
From: ext Baranski, Detlef [mailto:Detlef.Baranski@pilkington.de]
Sent: Thursday, November 17, 2005 11:22 AM
To: VRF
Subject: AW: [vrf] Matlab in VEE7.51 is not working if VEE6.01 is installe d on the same computer
I use almost same config with no prob.
Only advice: reinstall Vee 7.51 (do you own full version or just eval?) with standard feature . Use admin rights.
Best regards,
detlef
Von: manfred.weiss@nokia.com [ mailto:manfred.weiss@nokia.com]
Gesendet: Donnerstag, 17. November 2005 10:38
An: VRF
Betreff: [vrf] Matlab in VEE7.51 is not working if VEE6.01 is installed on the same computer
I have the following problem:
if I try to run one of the Matlab examples which are provided with VEE (for example Plot2DArray.vee) I always get the following error message from VEE 7.51
My computer:
WIN2000
VEE6.01
VEE7.51
Agilent IO-Library version 14
If I run the Matlab examples with VEE6.01 they work, but not with VEE7.51.
Has anybody an idea how to fix this problem?
Best regards
Manfred
You are currently subscribed to vrf as: manfred.weiss@nokia.com
Best Regards
Manfred
To: VRF
Best regards,
detlef
An: VRF
My computer:
WIN2000
VEE6.01
VEE7.51
Best regards
Manfred
