THANK YOU Qi
/Alex
From: GAO,QI (A-Sonoma,ex1) [mailto:qi_gao@agilent.com]
Sent: den 20 december 2005 04:58
To: VRF
Subject: RE: [vrf] Callable VEE, how does it work?
Hi Alex,
It's not "easy", but it's doable. What you need to do is to declare couple Record variables, initialize them, and then pass them around to your callable VEE server. Please see attached program.
Qi
From: Alexander Poulikakos (KI/EAB) [mailto:alexander.poulikakos@ericsson.com]
Sent: Monday, December 12, 2005 7:37 PM
To: VRF
Subject: [vrf] Callable VEE, how does it work?
Hi VRF
I'm trying to make a VEE application call another VEE application, via ActiveX.
How can I do this? I have checked the examples and there is no example
of VEE calling VEE. It's only various other applications calling VEE.
I have attched a VEE example, but I just can't get it to work?!?!?
What should the variable "Outputs" be initiated as?
I get an error message telling me:
"Value must be a 1 dimensional VARIANT array "Inputs" parameter of function "TwoInTwoOut"
Any help is appreciated.
Alex
You are currently subscribed to vrf as: qi_gao@agilent.com
You are currently subscribed to vrf as: alexander.poulikakos@ericsson.com
/Alex
To: VRF
Hi Alex,
Qi
To: VRF
Hi VRF
Alex
