AW: vrf VEE with Nat'l VISA
Question asked by detlef.baranski on Jan 9, 2006
It not that easy , sorry.
Read the Manual. There are different things to take care dependent on the
VEE Version you have.
Since Vee 7 you need NI Visa lib 3 or higher , otherwise it is not working.
With Iolib 14.1 and VEE 7.5 it should work without any big problems if Nilib
is installed first. But there were some troubles also....
So let us know if your attempt work.
Best regards,
detlef
Von: Drago, William @NARDAEAST [mailto:William.Drago@L-3com.com]
Gesendet: Freitag, 6. Januar 2006 16:38
An: VRF
Betreff: RE: [vrf] VEE with Nat'l VISA
Thanks, I'll give it a try.
Bill
From: BOCKSTAL,DANIEL (A-Belgium,ex1) [mailto:daniel_bockstal@agilent.com]
Sent: Friday, January 06, 2006 8:45 AM
To: VRF
Subject: RE: [vrf] VEE with Nat'l VISA
Hello Drago,
VEE will play nicely with NI's VISA, no problem. You can have a side by side
installation (NI VISA + Agilent VISA) on the same computer, but this is only
required if you mix Agilent's and NI's hardware (an Agilent GPIB card and an
NI GPIB card in the same PC)
Best regards
Daniel Bockstal
From: Drago, William @NARDAEAST [mailto:William.Drago@L-3com.com]
Sent: Friday, January 06, 2006 2:23 PM
To: VRF
Subject: [vrf] VEE with Nat'l VISA
All,
I have a test system running LabWindows/CVI and TestStand. I want to
installVEE runtime so I can use the equipment in that test system with some
of my VEE programs.
Will VEE play nice with the Nat'l VISA or does it need it's own? And, if it
does need it's own, can the two VISAs co-exist?
Bill
You are currently subscribed to vrf as: daniel_bockstal@agilent.com
You are currently subscribed to vrf as: William.Drago@l-3com.com
This e-mail and subsequent attachments may contain information which is
proprietary to L-3 Communications Corporation. The contents shall not be
disclosed, copied, distributed or used unless authorized by L-3
Communications Narda - East.
You are currently subscribed to vrf as: Detlef.Baranski@pilkington.de
