<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 3.2//EN"><HTML><HEAD><META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=iso-8859-1"><META NAME="Generator" CONTENT="MS Exchange Server version 5.5.2654.45"><TITLE>RE: [vrf] VEE with Nat'l VISA</TITLE></HEAD><BODY><P><FONT SIZE=2>All,</FONT></P><P><FONT SIZE=2>I installed VEE 7.0 runtime on my NI system yesterday and it worked. No problems at all.</FONT></P><P><FONT SIZE=2>Thanks,</FONT><BR><FONT SIZE=2>Bill</FONT></P><P><FONT SIZE=2>> -----Original Message-----</FONT><BR><FONT SIZE=2>> From: Baranski, Detlef [<A HREF="mailto:Detlef.Baranski@pilkington.de">mailto:Detlef.Baranski@pilkington.de</A>]</FONT><BR><FONT SIZE=2>> Sent: Tuesday, January 10, 2006 6:54 AM</FONT><BR><FONT SIZE=2>> To: 'Drago, William @NARDAEAST'; VRF</FONT><BR><FONT SIZE=2>> Subject: AW: [vrf] VEE with Nat'l VISA</FONT><BR><FONT SIZE=2>> </FONT><BR><FONT SIZE=2>> </FONT><BR><FONT SIZE=2>> It not that easy , sorry.</FONT><BR><FONT SIZE=2>> Read the Manual. There are different things to take care </FONT><BR><FONT SIZE=2>> dependent on the</FONT><BR><FONT SIZE=2>> VEE Version you have.</FONT><BR><FONT SIZE=2>> Since Vee 7 you need NI Visa lib 3 or higher , otherwise it </FONT><BR><FONT SIZE=2>> is not working.</FONT><BR><FONT SIZE=2>> With Iolib 14.1 and VEE 7.5 it should work without any big </FONT><BR><FONT SIZE=2>> problems if Nilib</FONT><BR><FONT SIZE=2>> is installed first. But there were some troubles also....</FONT><BR><FONT SIZE=2>> So let us know if your attempt work.</FONT><BR><FONT SIZE=2>> </FONT><BR><FONT SIZE=2>> Best regards,</FONT><BR><FONT SIZE=2>> detlef</FONT><BR><FONT SIZE=2>> </FONT><BR><FONT SIZE=2>> -----Ursprngliche Nachricht-----</FONT><BR><FONT SIZE=2>> Von: Drago, William @NARDAEAST [<A HREF="mailto:William.Drago@L-3com.com">mailto:William.Drago@L-3com.com</A>] </FONT><BR><FONT SIZE=2>> Gesendet: Freitag, 6. Januar 2006 16:38</FONT><BR><FONT SIZE=2>> An: VRF</FONT><BR><FONT SIZE=2>> Betreff: RE: [vrf] VEE with Nat'l VISA</FONT><BR><FONT SIZE=2>> </FONT><BR><FONT SIZE=2>> Thanks, I'll give it a try.</FONT><BR><FONT SIZE=2>> </FONT><BR><FONT SIZE=2>> Bill</FONT><BR><FONT SIZE=2>> -----Original Message-----</FONT><BR><FONT SIZE=2>> From: BOCKSTAL,DANIEL (A-Belgium,ex1) </FONT><BR><FONT SIZE=2>> [<A HREF="mailto:daniel_bockstal@agilent.com">mailto:daniel_bockstal@agilent.com</A>]</FONT><BR><FONT SIZE=2>> Sent: Friday, January 06, 2006 8:45 AM</FONT><BR><FONT SIZE=2>> To: VRF</FONT><BR><FONT SIZE=2>> Subject: RE: [vrf] VEE with Nat'l VISA</FONT><BR><FONT SIZE=2>> Hello Drago,</FONT><BR><FONT SIZE=2>> VEE will play nicely with NI's VISA, no problem. You can have </FONT><BR><FONT SIZE=2>> a side by side</FONT><BR><FONT SIZE=2>> installation (NI VISA + Agilent VISA) on the same computer, </FONT><BR><FONT SIZE=2>> but this is only</FONT><BR><FONT SIZE=2>> required if you mix Agilent's and NI's hardware (an Agilent </FONT><BR><FONT SIZE=2>> GPIB card and an</FONT><BR><FONT SIZE=2>> NI GPIB card in the same PC)</FONT><BR><FONT SIZE=2>> Best regards</FONT><BR><FONT SIZE=2>> Daniel Bockstal</FONT><BR><FONT SIZE=2>> </FONT><BR><FONT SIZE=2>> </FONT><BR><FONT SIZE=2>> </FONT><BR><FONT SIZE=2>> </FONT><BR><FONT SIZE=2>> From: Drago, William @NARDAEAST [<A HREF="mailto:William.Drago@L-3com.com">mailto:William.Drago@L-3com.com</A>] </FONT><BR><FONT SIZE=2>> Sent: Friday, January 06, 2006 2:23 PM</FONT><BR><FONT SIZE=2>> To: VRF</FONT><BR><FONT SIZE=2>> Subject: [vrf] VEE with Nat'l VISA</FONT><BR><FONT SIZE=2>> </FONT><BR><FONT SIZE=2>> All,</FONT><BR><FONT SIZE=2>> </FONT><BR><FONT SIZE=2>> I have a test system running LabWindows/CVI and TestStand. I want to</FONT><BR><FONT SIZE=2>> installVEE runtime so I can use the equipment in that test </FONT><BR><FONT SIZE=2>> system with some</FONT><BR><FONT SIZE=2>> of my VEE programs.</FONT><BR><FONT SIZE=2>> </FONT><BR><FONT SIZE=2>> Will VEE play nice with the Nat'l VISA or does it need it's </FONT><BR><FONT SIZE=2>> own? And, if it</FONT><BR><FONT SIZE=2>> does need it's own, can the two VISAs co-exist?</FONT><BR><FONT SIZE=2>> </FONT><BR><FONT SIZE=2>> Thanks,</FONT><BR><FONT SIZE=2>> Bill</FONT><BR><FONT SIZE=2>> </FONT><BR><FONT SIZE=2>> --- </FONT><BR><FONT SIZE=2>> You are currently subscribed to vrf as: daniel_bockstal@agilent.com </FONT><BR><FONT SIZE=2>> To subscribe send a blank email to </FONT><BR><FONT SIZE=2>> "join-vrf@it.lists.it.agilent.com". </FONT><BR><FONT SIZE=2>> To unsubscribe send a blank email to </FONT><BR><FONT SIZE=2>> "leave-vrf@it.lists.it.agilent.com". </FONT><BR><FONT SIZE=2>> To send messages to this mailing list, email "vrf@agilent.com". </FONT><BR><FONT SIZE=2>> If you need help with the mailing list send a message to</FONT><BR><FONT SIZE=2>> "owner-vrf@it.lists.it.agilent.com". </FONT><BR><FONT SIZE=2>> Search the "unofficial vrf archive" at </FONT><BR><FONT SIZE=2>> "www.oswegosw.com/vrf_archive/". </FONT><BR><FONT SIZE=2>> </FONT><BR><FONT SIZE=2>> --- </FONT><BR><FONT SIZE=2>> You are currently subscribed to vrf as: William.Drago@l-3com.com </FONT><BR><FONT SIZE=2>> To subscribe send a blank email to </FONT><BR><FONT SIZE=2>> "join-vrf@it.lists.it.agilent.com". </FONT><BR><FONT SIZE=2>> To unsubscribe send a blank email to </FONT><BR><FONT SIZE=2>> "leave-vrf@it.lists.it.agilent.com". </FONT><BR><FONT SIZE=2>> To send messages to this mailing list, email "vrf@agilent.com". </FONT><BR><FONT SIZE=2>> If you need help with the mailing list send a message to</FONT><BR><FONT SIZE=2>> "owner-vrf@it.lists.it.agilent.com". </FONT><BR><FONT SIZE=2>> Search the "unofficial vrf archive" at </FONT><BR><FONT SIZE=2>> "www.oswegosw.com/vrf_archive/". </FONT><BR><FONT SIZE=2>> This e-mail and subsequent attachments may contain </FONT><BR><FONT SIZE=2>> information which is</FONT><BR><FONT SIZE=2>> proprietary to L-3 Communications Corporation. The contents </FONT><BR><FONT SIZE=2>> shall not be</FONT><BR><FONT SIZE=2>> disclosed, copied, distributed or used unless authorized by L-3</FONT><BR><FONT SIZE=2>> Communications Narda - East.</FONT><BR><FONT SIZE=2>> </FONT><BR><FONT SIZE=2>> --- </FONT><BR><FONT SIZE=2>> You are currently subscribed to vrf as: Detlef.Baranski@pilkington.de </FONT><BR><FONT SIZE=2>> To subscribe send a blank email to </FONT><BR><FONT SIZE=2>> "join-vrf@it.lists.it.agilent.com". </FONT><BR><FONT SIZE=2>> To unsubscribe send a blank email to </FONT><BR><FONT SIZE=2>> "leave-vrf@it.lists.it.agilent.com". </FONT><BR><FONT SIZE=2>> To send messages to this mailing list, email "vrf@agilent.com". </FONT><BR><FONT SIZE=2>> If you need help with the mailing list send a message to</FONT><BR><FONT SIZE=2>> "owner-vrf@it.lists.it.agilent.com". </FONT><BR><FONT SIZE=2>> Search the "unofficial vrf archive" at </FONT><BR><FONT SIZE=2>> "www.oswegosw.com/vrf_archive/". </FONT><BR><FONT SIZE=2>> </FONT></P><P><FONT SIZE=2> This e-mail and subsequent attachments may contain information which is proprietary to L-3 Communications Corporation. The contents shall not be disclosed, copied, distributed or used unless authorized by L-3 Communications Narda - East.</FONT></P><BR>---<BR>You are currently subscribed to vrf as: rsb@soco.agilent.com<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".<BR>Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/".</BODY></HTML>
