The data I'm dealing with is all unsigned when it comes off the wire, so I
assume there are no negatives to deal with there.
Thanks for the warning, should I ever reuse that code.
Graeme Hilton
R&D Engineer
Schlumberger Sensa
Bill Ossmann wrote the following on 02/11/2005 16:25:
> I don't know if you have to deal with negative numbers, but if you do I
> think that formula will cause an integer overflow for an int16, or not give
> the expected 2's complement as an int32.
> Bill Ossmann
> Philips Ultrasound
> e-mail: bill.ossmann@philips.com
> Graeme Hilton <GHilton@slb.com> wrote on 11/02/2005 10:00:12 AM:
>> Thanks Dave,
>> I had to fiddle a little to get this to accept my data, but it works
> well.
>> However, I persevered a little more with the socket reading and came
>> up with this:
>> From Socket, READ BINARY x BYTE ARRAY:16001,2
>> Then a formula: (x[*,1]*256+x[*,0]) to marry the two columns of
>> bytes together.
>> Very quick and very simple.
>> Graeme Hilton
>> R&D Engineer
>> Schlumberger Sensa
>> David Watling wrote the following on 02/11/2005 14:08:
>>> Hi Graeme,
>>> I wrote a byteswop formula which works on all elements of the array at
>>> once. Load the array as INT16, then run the swopper function. You may
>>> or may not want the 2's cmpl function as well.
>>> Function byteswop int16:
>>> bitOr(bitAnd(bitShift(A,-8),#H00ff),bitAnd(bitShift(A,8),#Hff00));
>>> 2's cmpl
>>> asInt16(A-(A DIV 32768)*65536);
>>> Regards
>>> David Watling
>>> -----Original Message-----
>>> From: Graeme Hilton [mailto:GHilton@slb.com]
>>> Sent: 02 November 2005 13:43
>>> To: VRF
>>> Subject: [vrf] Array of bytes convert to array of int16s
>>> Hi All,
>>> Here's my latest puzzle;
>>> I am reading data from a TCP/IP socket. I read 32002 bytes which
>>> represent
>>> 16001 16-bit integers. I can't use the READ BINARY x INT16 ARRAY1D
>>> 16001 as the
>>> data is presented as LSB first whereas the To/From Socket object
> assumes
>>> it's
>>> MSB first.
>>> To stitch these numbers together I run through the following:
>>> For Each (A[2*i]+A[(2*i)+1]*256) and collect the results to create my
>>> int16
>>> array of 16001 elements.
>>> My problem is that this takes a significant amount of time (compared to
>>> the rest
>>> of the program). Does anyone have a non-looping way of doing this or
>>> another
>>> time-saving method?
>> You are currently subscribed to vrf as: bill.ossmann@philips.com
>> To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".
>> To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".
>> To send messages to this mailing list, email "vrf@agilent.com".
>> If you need help with the mailing list send a message to "owner-
>> Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/".
> You are currently subscribed to vrf as: GHilton@slb.com
> If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".
Graeme Hilton
R&D Engineer
Schlumberger Sensa
> Bill Ossmann
> Philips Ultrasound
>> Thanks Dave,
> well.
>> up with this:
>> bytes together.
>> Graeme Hilton
>> R&D Engineer
>> Schlumberger Sensa
>>> Hi Graeme,
>>> 2's cmpl
>>> Regards
>>> David Watling
>>> To: VRF
>>> Hi All,
>>> represent
>>> 16001 as the
> assumes
>>> it's
>>> MSB first.
>>> int16
>>> the rest
>>> another
>>> time-saving method?
> assumes it's MSB first.
Oh my! Well, yes I can think of a faster way but I think the larger problem
is that whatever is sending the data is incorrect! Network byte order is
supposed to be transparent to the application layer. IOW, htons() was not
used in the first place.
Basically, just move the bytes into an Int16 array en masse. I'll elaborate
when I get back from today's little side track if no other solution presents
itself in the mean time.
-SHAWN-
