AW: vrf Program already running
Question asked by detlef.baranski on Oct 27, 2005
Other solution trial- shot from the knee to the neck....
By starting your application the first time look if a flag file is there.If
it is not, then store this flag-file . If you start it twice, you see that
it is still  there , so you know that your app was running before...
Best regards,
detlef
Von: Shawn Fessenden [mailto:shawn@testech-ltd.com]
Gesendet: Mittwoch, 26. Oktober 2005 12:45
An: VRF
Betreff: RE: [vrf] Program already running
> I believe I was the one asking for
> a method to allow determining if a
> program was already running - and
> I'm still interested in a solution.
Oh yeah. Ok, if I remember correctly process enumeration doesn't work
because the process is always veerun or cmd or command, and window
enumeration doesn't work because you don't know the window title or titles
could be duplicated. So I figured that what it boiled down to was getting
the command line of a foreign process. Ah yes it's all coming back to me
now.
I recently found a code injection library that seems to work a whole lot
better than the other one. I'm going to revisit this whole problem soon.
-SHAWN-
You are currently subscribed to vrf as: Detlef.Baranski@pilkington.de
This message and any attachments are confidential, for the exclusive use of
the addressee and may be legally privileged. Any other distribution, use or
reproduction is unauthorised and prohibited. If you have received this
message in error, please notify the sender immediately and delete the
message from your system.
     Visit our internet site at http://www.pilkington.com
