<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"><html><head> <meta content="text/html;charset=ISO-8859-1" http-equiv="Content-Type"></head><body bgcolor="#ffffff" text="#000000">
I need print total main detail view, I try use virtual printer with MDI (multi-document interface). But the problem is that I can´t seetotal main detail view, I see total detail view of object and function.What is the problem, why I can´t see the total main detail view.
Best Regard,
Carlos Jiménez
<img alt="Mi firma" src="cid:part1.08050100.06070001@ivic.ve" height="506" width="512">
<div class="moz-signature">--
</div><BR>---<BR>You are currently subscribed to vrf as: rsb@soco.agilent.com<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list, email "vrf@agilent.com". <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".<BR>Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/".</BODY></html>
Best Regard,
Carlos Jiménez
I currently have a vee program controlling a radio
over a network. The program is used for spectral
scanning (using the mag spectrum as the main
interface) and works pretty decent but I need some
help in a few areas.
Can someone point me in the right direction for
implementing click tune? I would like to click on the
spectrum and tune the radio to the current mouse
position. I noticed that I can use the marker
feature, but I only want this to happen when the
cursor is moved. The basic interface uses drop boxes
and text input to select receiver mod/bw/frequency/and
sweep size so the goal is to click on an active signal
and then capture the IF and audio.
Jeff
