vrf Vacant position
Question asked by VRFuser on May 1, 2003
I have been running a system since early January using Win2k, Vee 6.01 and a DT321 card.  Last week I started to see the test programme occasionally freezing at an 'A/D Config' and 'Get Data Panel' combination.  The only strange thing I have noticed is that the hSubsys value is '1' when a freeze occurs rather than the usual multidigit value.  In desperation I have created a new run time version from the original Pro. version and so far I have not seen any further occurrences of the freezing.  Does anyone have any idea as to what could be happening?  Can runtime programmes become corrupted?
Ivan Edwards
Senior Engineer,
InfraRed Integrated Systems Ltd.,
Towcester Mill,
Towcester,
Northants (UK).
NN12 6AD.
Tel:   +44 (0)1327 357824
Fax:   +44 (0)1327 357825
Website: www.irisys.co.uk
This e-mail message is confidential and for use by the addressee only. If the message is received by anyone other than the addressee, please return the message to the sender by replying to it and then delete the message from your computer. Internet e-mails are not necessarily secure. InfraRed Integrated Systems Ltd. (IRISYS) does not accept responsibility for changes made to this message after it was sent.
Whilst all reasonable care has been taken to avoid the transmission of viruses, it is the responsibility of the recipient to ensure that the onward transmission, opening or use of this message and any attachments will not adversely affect its systems or data. No responsibility is accepted by IRISYS in this regard and the recipient should carry out such virus and other checks as it considers appropriate.
