vrf Question on 34980A
Question asked by fukui.yutaka on Oct 14, 2005
Check the "DynamicFindRemoteInstruments.vee".
You will know which I/F a 34980A is connected to with this program.
Help -> "Open Example..." -> InstrumentIO
This program uses the DynamicIO automation
server to find all availabe interfaces and
instruments on a local or remote PC. The
remote PC must have Agilent VEE installed
for remote instrument discovery to work.
Warning: the remote object creation may
fail and there may be a long period of time
during which nothing seems to be happening
before you get an object creation error.
Please be patient.
Next set the proper Instrument Visa Resource String to the 34980A.
"Function & Object Browser" ->
Type: Instrument
Instrument Category: GPIB Instrument(for example)
Configured Instrument: Your 34980a
Members:pnpResource
-> "Create Set Formula"
FUKUI Yutaka
Thomas.Mitchell@Autoliv.com wrote:
> I'm in the beginning phases of a large project using the Agilent 34980A
> switch box.  What I want to be able to do is test all 3 interfaces and
> detect which one that this switch box is connected to.  For example, when I
> start my program, look for it on USB, if it's not there, try LAN, if its
> still not there, then try GPIB, then use that interface throughout the
> program.
> Any idea on the best way to do this would be?
> Thanks
> Tom Mitchell
> Autoliv AEA
> You are currently subscribed to vrf as: fukui.yutaka@jp.fujitsu.com
> To send messages to this mailing list,  email "vrf@agilent.com".
> If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".
> Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/".
*  $BJ!0f!!K-!J (BFUKUI Yutaka)
* E-Mail: fukui.yutaka@jp.fujitsu.com
*  $BIY;NDL3t<02q<R!!@n:j9)>l (B
*  $B$b$N$E$/$j?d?JKIt!&@8;:5;=Q3+H/E}3gIt!!;n835;=Q (BPj <-- 2004/10/01 $B$h$j (B
$B?&@)$,JQ$j$^$7$? (B
*  $B7WB,@_Hw3+H/It (BHomePage http://www.psl.fujitsu.co.jp/htd2/ksk/
*  $B@n:j;TCf866h>e>.EDCf#4 (B- $B#1 (B- $B#1!!M9JXHV9f!' (B211-8588
* TEL  $B!!30@~ (B 044-754-2238, $B!!Fb@~ (B 711-5-3153 <-- 2005/05/23 $B$h$jEEOCHV9f$, (B
$BJQ$j$^$7$? (B
* FAX  $B!!30@~ (B 044-754-2434, $B!!Fb@~ (B 711-5-3178
