I'm not familiar with the 5070B or 5071B but it could be that the firmware
in the instruments is different and therefore it may not be possible to load
a 5070B instrument state on a 5071B.
After upgrading the firmware on a HP8719ES Network Analyser I found it would
not load old instrument states I has saved off before.
Dave Evanson
Characterisation Engineer
From: Alex.Barrett@raytheon.co.uk [mailto:Alex.Barrett@raytheon.co.uk]
Sent: 17 June 2005 11:05
To: VRF
Subject: [vrf] Network Analyer people - HELP!! - (5070B)
All, - and apologies for this non vee mail but am very stressed!!!
Does anyone know how to get a state file from a 5070B to work on a 5071B?-
They are the same instrument, but the 5071 is an 8.5GHz variant.
When trying to load the state it just says 'recall failed'.
If anyone has any experience of this or ideas, please, please mail of call
me..
Thanks, - and sorry again to the vee guys
Alex.
+44 1279 407768
(Embedded image moved to
file: pic21718.gif)
(Embedded Alex Barrett
image moved Test Development Engineer
to file: Raytheon Systems Limited
pic03753.gif) The Pinnacles
Harlow
Essex CM19 5BB
United Kingdom
( +44 (0) 1279 407768
( +44 (0) 1279 407620 fax
You are currently subscribed to vrf as: devanson@zetex.com
_________________________________________________________
Zetex Semiconductors - Solutions for an analog world.
To read the latest news from Zetex, read our ZetexPress newsletter
online at www.zetex.com/zetexpress
http://www.zetex.com
E-MAILS are susceptible to interference. You should not assume that
the contents originated from the sender or the Zetex Group or that they
have been accurately reproduced from their original form.
Zetex accepts no responsibility for information, errors or omissions in
this e-mail nor for its use or misuse nor for any act committed or
omitted in connection with this communication.
If in doubt, please verify the authenticity with the sender.
> The development profiler appears to show that the only code running is a
> few event driven serial input functions. Looking at these code threads
> shows that they are running periodically without problems - exactly as
> expected. I can't find any signs of life in any of the other code
> threads, including a simply looping time display.
did I understand you correctly that your program did stop executing but from VEE-development it still seems to run?
So when you trace the currently active vee objects with the green boxes (execution flow) you see some objects that are light green and vee seems to hang here?
If so, and your 'event driven serial input functions' pointed me to that direction, I stromgly assume a deadlock due to the fact that vee cannot execute a function when it is already running: if function A is executing and an event interrupts that execution and tries to call function A again this deadlock occurs - without any error message or such.
If you use events as kind of interrupt routines keep trhe following things in mind:
- make the interrupt routine as short and quick as possible (this was true on the old 8088 - and is still)
- do not call any functions from the interrupt routine. A solution is often to raise a flag here and test it on a 'parallel' vee thread. There cou can safely call the desired function.
I hope that was your problem and I could give you some assistance
best regards,
Georg
Georg Nied Software-Development Hansestr. 7 51149 Cologne Germany
Tel: +49 (2203) 9770915 Fax: +49 (2203) 9770924 E-Mail: info@gn-software.de
