vrf VEE with Nat'l VISA
Question asked by daniel_bockstal on Jan 5, 2006
<html xmlns:v="urn:schemas-microsoft-com:vml" xmlns:o="urn:schemas-microsoft-com:office:office" xmlns:w="urn:schemas-microsoft-com:office:word" xmlns="http://www.w3.org/TR/REC-html40"><head><META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=us-ascii"><meta name=Generator content="Microsoft Word 11 (filtered medium)"><!--[if !mso]><style>v:* {behavior:url(#default#VML);}o:* {behavior:url(#default#VML);}w:* {behavior:url(#default#VML);}.shape {behavior:url(#default#VML);}</style><![endif]--><style><!-- /* Font Definitions */ @font-face     {font-family:Tahoma;     panose-1:2 11 6 4 3 5 4 4 2 4;}@font-face     {font-family:Verdana;     panose-1:2 11 6 4 3 5 4 4 2 4;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal     {mso-margin-top-alt:auto;     margin-right:0cm;     mso-margin-bottom-alt:auto;     margin-left:0cm;     font-size:12.0pt;     font-family:"Times New Roman";     mso-believe-normal-left:yes;}a:link, span.MsoHyperlink     {color:blue;     text-decoration:underline;}a:visited, span.MsoHyperlinkFollowed     {color:#606420;     text-decoration:underline;}span.EmailStyle17     {mso-style-type:personal-reply;     font-family:Arial;     color:navy;}@page Section1     {size:612.0pt 792.0pt;     margin:72.0pt 90.0pt 72.0pt 90.0pt;}div.Section1     {page:Section1;}--></style><![if mso 9]><style>p.MsoNormal     {margin-left:7.5pt;}</style><![endif]><!--[if gte mso 9]><xml> <o:shapedefaults v:ext="edit" spidmax="1026" /></xml><![endif]--><!--[if gte mso 9]><xml> <o:shapelayout v:ext="edit">  <o:idmap v:ext="edit" data="1" /> </o:shapelayout></xml><![endif]--></head><body bgcolor="#FFFFF7" lang=EN-US link=blue vlink="#606420" style='margin-left:7.5pt'><div class=Section1><p class=MsoNormal><font size=2 color=navy face=Arial><span style='font-size:10.0pt;font-family:Arial;color:navy'>Hello Drago,<o:p></o:p></span></font></p><p class=MsoNormal><font size=2 color=navy face=Arial><span style='font-size:10.0pt;font-family:Arial;color:navy'>VEE will play nicely with NI’s VISA,no problem. You can have a side by side installation (NI VISA + Agilent VISA)on the same computer, but this is only required if you mix Agilent’s andNI’s hardware (an Agilent GPIB card and an NI GPIB card in the same PC)<o:p></o:p></span></font></p><p class=MsoNormal><font size=2 color=navy face=Arial><span style='font-size:10.0pt;font-family:Arial;color:navy'> Best regards<o:p></o:p></span></font></p><p class=MsoNormal><font size=2 color=navy face=Arial><span style='font-size:10.0pt;font-family:Arial;color:navy'>Daniel Bockstal<o:p></o:p></span></font></p><p class=MsoNormal><font size=2 color=navy face=Arial><span style='font-size:10.0pt;font-family:Arial;color:navy'><o:p> </o:p></span></font></p><p class=MsoNormal><font size=2 color=navy face=Arial><span style='font-size:10.0pt;font-family:Arial;color:navy'><o:p> </o:p></span></font></p><p class=MsoNormal><font size=2 color=navy face=Arial><span style='font-size:10.0pt;font-family:Arial;color:navy'><o:p> </o:p></span></font></p><div><div class=MsoNormal align=center style='margin:0cm;margin-bottom:.0001pt;text-align:center'><font size=3 face="Times New Roman"><span style='font-size:12.0pt'><hr size=2 width="100%" align=center tabindex=-1></span></font></div><p class=MsoNormal style='margin:0cm;margin-bottom:.0001pt'><b><font size=2face=Tahoma><span style='font-size:10.0pt;font-family:Tahoma;font-weight:bold'>From:</span></font></b><fontsize=2 face=Tahoma><span style='font-size:10.0pt;font-family:Tahoma'> Drago,William @NARDAEAST [mailto:William.Drago@L-3com.com]
<b><span style='font-weight:bold'>Sent:</span></b> Friday, January 06, 20062:23 PM
<b><span style='font-weight:bold'>To:</span></b> VRF
<b><span style='font-weight:bold'>Subject:</span></b> [vrf] VEE with Nat'l VISA</span></font><o:p></o:p></p></div><p class=MsoNormal><font size=3 face="Times New Roman"><span style='font-size:12.0pt'><o:p> </o:p></span></font></p><div><p class=MsoNormal style='margin:0cm;margin-bottom:.0001pt'><font size=2color=black face=Verdana><span style='font-size:10.0pt;font-family:Verdana;color:black'>All,</span></font><font color="#333333" face=Verdana><spanstyle='font-family:Verdana;color:#333333'><o:p></o:p></span></font></p></div><div><p class=MsoNormal style='margin:0cm;margin-bottom:.0001pt'><font size=3color="#333333" face=Verdana><span style='font-size:12.0pt;font-family:Verdana;color:#333333'> <o:p></o:p></span></font></p></div><div><p class=MsoNormal style='margin:0cm;margin-bottom:.0001pt'><font size=2color=black face=Verdana><span style='font-size:10.0pt;font-family:Verdana;color:black'>I have a test system running LabWindows/CVI and TestStand. I wantto install VEE runtime so I can use the equipment in that test system withsome of my VEE programs.</span></font><font color="#333333" face=Verdana><spanstyle='font-family:Verdana;color:#333333'><o:p></o:p></span></font></p></div><div><p class=MsoNormal style='margin:0cm;margin-bottom:.0001pt'><font size=3color="#333333" face=Verdana><span style='font-size:12.0pt;font-family:Verdana;color:#333333'> <o:p></o:p></span></font></p></div><div><p class=MsoNormal style='margin:0cm;margin-bottom:.0001pt'><font size=2color=black face=Verdana><span style='font-size:10.0pt;font-family:Verdana;color:black'>Will VEE play nice with the Nat'l VISA or does it need it's own?And, if it does need it's own, can the two VISAs co-exist?</span></font><fontcolor="#333333" face=Verdana><span style='font-family:Verdana;color:#333333'><o:p></o:p></span></font></p></div><div><p class=MsoNormal style='margin:0cm;margin-bottom:.0001pt'><font size=3color="#333333" face=Verdana><span style='font-size:12.0pt;font-family:Verdana;color:#333333'> <o:p></o:p></span></font></p></div><div><p class=MsoNormal style='margin:0cm;margin-bottom:.0001pt'><font size=2color=black face=Verdana><span style='font-size:10.0pt;font-family:Verdana;color:black'>Thanks,</span></font><font color="#333333" face=Verdana><spanstyle='font-family:Verdana;color:#333333'><o:p></o:p></span></font></p></div><div><p class=MsoNormal style='margin:0cm;margin-bottom:.0001pt'><font size=2color=black face=Verdana><span style='font-size:10.0pt;font-family:Verdana;color:black'>Bill</span></font><font color="#333333" face=Verdana><spanstyle='font-family:Verdana;color:#333333'><o:p></o:p></span></font></p></div><p class=MsoNormal style='margin:0cm;margin-bottom:.0001pt'><font size=3color="#333333" face=Verdana><span style='font-size:12.0pt;font-family:Verdana;color:#333333'>
You are currently subscribed to vrf as: daniel_bockstal@agilent.com
To subscribe send a blank email to"join-vrf@it.lists.it.agilent.com".
If you need help with the mailing list send a message to"owner-vrf@it.lists.it.agilent.com".
Search the "unofficial vrf archive" at"www.oswegosw.com/vrf_archive/". <o:p></o:p></span></font></p></div><BR>---<BR>You are currently subscribed to vrf as: rsb@soco.agilent.com<BR>To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".<BR>To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".<BR>To send messages to this mailing list,  email "vrf@agilent.com".  <BR>If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".<BR>Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/".</BODY></html><BR><P><FONT SIZE=2 FACE="Arial"> This e-mail and subsequent attachments may contain information which is proprietary to L-3 Communications Corporation. The contents shall not be disclosed, copied, distributed or used unless authorized by L-3 Communications Narda - East.</FONT></P>
