Thomas,
Did you check the register for Activex automation references and Activex
control ref. between these two computer? Usually, the new computer need
to
Add-in or config for Activex control and/or automation references.
Han
From: Thomas.Mitchell@Autoliv.com [mailto:Thomas.Mitchell@Autoliv.com]
Sent: Monday, April 25, 2005 6:23 AM
To: VRF
Subject: [vrf] ActiveX & Library question
I've run into a strange problem. I have VEE program that I use as a
library for my main test programs. I can run the library by itself, and
the functions work properly. Until recently, I could also merge these
libraries into my main program and call the functions, and every thing
worked fine. I installed these on a new computer, and now, my library
executes fine, but when called by my main program, they do not work
right.
I had thought at first that it might of been a problem with office 2003
and
windows 2000. But I had office 2003 removed, and installed office 2000,
but I still have the same problem.
Any ideas?
You are currently subscribed to vrf as: tranh@tycoelectronics.com
to
Han
To: VRF
right.
and
Any ideas?
This is where error handling becomes critical. There are *so* many different
possibilities. Maybe start with pathing problems, versional dependencies &
whatnot. Also, be sure to single step through the problem areas to confirm
proper execution flow. You never know when that wacky flow bug will jump up
and bite you.
-SHAWN-
