Scan,
Can Vee set field name as a variable in get Record. For example,
Rec.A; A is an input terminal to the get record formular
And A is not a field name; it is a variable = John and John is a
Field name is this record.
I tried and it gave me an error that A is not a field name.
Han
From: Stan Bischof (Richard S) [mailto:rsb@soco.agilent.com]
Sent: Tuesday, April 12, 2005 11:31 AM
To: VRF
Cc: vrf@agilent.com
Subject: Re: [vrf] programmatically enter field names in Records
"John Wing" <jwing@psemc.com> wrote:
> Is it possible to programmatically enter field names when building
records?
> John
yes, but not using the built-in objects. you need to create a function
that does this. Browse the archives and you'll find several examples.
Stan
You are currently subscribed to vrf as: tranh@tycoelectronics.com
Han
To: VRF
Cc: vrf@agilent.com
records?
> John
Stan
The information contained in this message may be sensitive and is for
the intended addressee only. Any unauthorized use, dissemination of the
information, or copying of this message is prohibited. If you are not
the intended addressee, please notify the sender immediately and delete
this message.
