Bingo
A function like " getting active cell " is missing in vxl. This should be
an -ask for enhancement-thing for Vee 8 .
One quick and dirty solution is - use a macro in which the active cell is
written in a certain defined cell and then ask for this cell data via
VXL....aeh EcxelLib
detlef
Von: Richard Kleinhenz [mailto:scubaman@us.ibm.com]
Gesendet: Dienstag, 15. November 2005 19:04
An: VRF
Betreff: Re: AW: [vrf] ActiveX Spreadsheet object
"Baranski, Detlef" <Detlef.Baranski@pilkington.de> wrote on 11/15/2005
12:35:37 PM:
> Andie,
> with VEE 7.5 you also get the excel - library support. So normally
> you do not need these ActixeX -stuff anymore.
> Just use the lego blocks from the VEE -Excel menue and voila
> To understand how it works have a look for the excel examples. It is
> much easier than the activ-x stuff.
> Just in case you need more complex scripts, have a look for the
> example how you can run the excel macros directly from excel.
> So at the end there is really no need for actveX-Excel calls anymore
> since vee7.5 - beside the fact you want to use old written code ....
Hmmm... here's something I'd like to do, but am not sure how to accomplish
in VXL or the excel stuff of 7.5: I'd like to open a spreadsheet, have the
user scroll to a cell, then let Vee know that cell so it can bring in that
row of data. Can this be done w/o explicit activeX?
In principle I agree - this new inclusion is an excellent extension of Vee.
I've been using vxl in previous versions
Rich
Richard Kleinhenz
Wafer Engineering
845-892-2617
scubaman@us.ibm.com
You are currently subscribed to vrf as: Detlef.Baranski@pilkington.de
VXL....aeh EcxelLib
detlef
An: VRF
12:35:37 PM:
> Andie,
Rich
Richard Kleinhenz
Wafer Engineering
845-892-2617
scubaman@us.ibm.com
