vrf VEE runtime on Win98SE
Question asked by VRFuser on Feb 27, 2006
Hi;
I was under the impression that VEE 7.5 IS Win 98 compatible with the addition of a DLL (?) to handle DDE exchange between window apps. I'm told, although I have not yet checked, that this add on is available from Agilent. Is this correct?
Tx
Mark
Sent: Monday, February 27, 2006 1:36 AM
To: VRF
Subject: Re: [vrf] VEE runtime on Win98SE
Hello!
Your discovery is indeed correct. It is because of the usage of DotNet controls in 7.5 and later versions that Win98SE is no longer a valid version. Indeed the current release of the IOLIBs only run on XP and 2000.
Gregg C Levine gregg.drwho8@gmail.com
"This signature was once found posting rude messages in English in the Moscow subway."
On 2/27/06, Lapworth, David <David.Lapworth@airservicesaustralia.com>
wrote:
> Is it possible to get VEE 7.51 runtime to install on a Windows 98SE
> machine?  The handbook says that it is compatible with Win98SE, WinME,
> Win2000, WinXP etc. but the actual installation program ends with a
> message that it is only compatible with Win2000 or WinXP.
> TIA
> David
> You are currently subscribed to vrf as: gregg.drwho8@gmail.com To
> subscribe send a blank email request to
"join-vrf@lists.it.agilent.com".
> To send messages to this mailing list,  email "vrf@agilent.com".
> Search the "unofficial vrf archive" at
"www.oswegosw.com/vrf_archive/".
You are currently subscribed to vrf as: mcarangi@gulton.com To subscribe send a blank email request to "join-vrf@lists.it.agilent.com".
