Good stuff!
I have used them years without problems (knock knock:). Extremely easy to program with their Vee lib (makes it's own menu to Vee developer UI). Remember to order that too (not free).
BR Tapio
________________________________
Lhettj: ext Schlieker, Reiner [mailto:reiner.schlieker@siemens.com]
Lhetetty: ke 20.4.2005 21:23
Vastaanottaja: VRF
Aihe: RE: [vrf] Digital IO using VEE
Check out http://www.measurementcomputing.com/
Reiner
From: Goderich, Damian [mailto:damian.goderich@boeing.com]
Sent: Wednesday, April 20, 2005 1:52 PM
To: VRF
Subject: [vrf] Digital IO using VEE
> Hi all,
Are there any Digital IO cards that software controllable
through VEE out there? I know National Instruments makes them but I am
trying to stay away from LabView.
I need to do the following cheap and efficient.
I know it can be done with VEE and a logic analyzer or pattern
generator, but that is expensive.
1. Send out a total of 11 bits of parallel data (TTL).
(This I can do with hardware I currently have, which is a
HP34970A, and a HP34903A 20-Channel General Switch. (Pull-up to 5V or
down to ground.)
2. 48 bits of serial data at a 1Mb/s rate, every 20mS.
I know step 1 can be down in Visual Basic or C to program the
parallel port, but I would like to keep it all in VEE since I am also
controlling GPIB Equipment after the commands are sent out. Also the PC
serial port is not fast enough for step 2.
Again I know NI has plenty of Digital IO cards out there that
will do this, but has anyone tackled something like this in VEE.
I would appreciate any suggestions.
Thanks
Damian.
You are currently subscribed to vrf as: reiner.schlieker@siemens.com
You are currently subscribed to vrf as: tapio.ronkainen@nokia.com
BR Tapio
Vastaanottaja: VRF
Reiner
To: VRF
> Hi all,
down to ground.)
Thanks
Damian.
