My only thought is. Do you have admin on the accounts you want to run the active X control in?
________________________________
From: ext John Scholten [mailto:jscholten@aimsys.nl]
Sent: 07 February 2006 09:34
To: VRF
Subject: [vrf] Access Violation on activeX control
I'm experiencing difficulties with an ActiveX control.
Within Windows XP Pro, I installed various accounts (some local and some coupled to a domain).
Agilent VEE applications run fine on all account, however for some accounts it's not possible to use an ActiveX control.
The control can be selected in the ActiveX control references but the device cannot be created. Vee responds with an access violation.
As far as I figured out the problem has something to do with XP SP2.
Somebody evere experienced a problem like this and is their any solution?
John
You are currently subscribed to vrf as:
Charles.Stewart@vertu.com
To subscribe send an email request to
Search the "unofficial vrf archive" at
"www.oswegosw.com/vrf_archive/".
This message has been scanned for viruses and is believed to be clean.
To subscribe send an email request to "owner-vrf@it.lists.it.agilent.com".
To: VRF
John
To: VRF
solution?
John
clean.
