vrf Error in VEE 7.0 by using the find instruments command
Question asked by VRFuser on Feb 9, 2005
Do you miss some DLLs in your system direcotry?
Jeremy
----- Original Message -----
From: "Abraham Mario" <M.Abraham@lasercomponents.com>
To: "VRF" <vrf@agilent.com>
Sent: Wednesday, February 09, 2005 10:53 PM
Subject: [vrf] Error in VEE 7.0 by using the find instruments command
Dear Vee-Users,
As I tried to find some instruments via the I/O Instrument Manager an error
message appears. Should I use this function any more or should I only use
the Agilent I/O Control?
Attached are the error messages.
<<VEE-Error.doc>>
Best regards,
Mario Abraham
LASER COMPONENTS GmbH
Werner-von-Siemens-Str. 15
82140 Olching / Germany
Tel.: +49 8142 2864 69
Fax: +49 8142 2864 11
www.lasercomponents.com
> You are currently subscribed to vrf as: wong@miko.com.hk
> To send messages to this mailing list,  email "vrf@agilent.com".
