vrf note pad
Question asked by VRFuser on Aug 4, 2008
Depends upon wither you will allow the user to edit the data or not.  But I’m confused, if the user already has access to the text data that created the file, it seems to me the user can already see the displayed data.  So I guess, you did not allow the user to create the text programmatically.
Anyway, if you have a text file why not simply show the text within an alphanumeric display.  If you will allow the user to edit the text, then place the lines into a constant text array and read the text back into a text file.  Of course you know how to use the panel object?
Rufus
  _____
Sent: Sunday, August 03, 2008 7:12 AM
To: VRF
Subject: [vrf] note pad
hi all
i design a communication server using vee, that control a radio and i want to give the user the facility to write his message in a txt file then when he want to transmit it the system will show it to him
so how to review a txt file with the note pad element, i thought that i can write to the the template file then by pressing a button to execute another user object contain the note pad element this will refresh it and show the file contents ( as attached prog. ) ...... but nothing happened .... can i do this ? or any another ideas ..!!
ok
You are currently subscribed to vrf as: Rufus.Warren@herley.com
  _____
The information contained in this message may be confidential and legally privileged. If you are not the intended recipient of this email and its attachments, you must take no action based upon them, nor must you copy or show them to anyone.
Please contact the sender if you believe you have received this email in error.
You are currently subscribed to vrf as: hua_jing@agilent.com
