> I've been using the IE WebBrowser_V1 control (shdocvw.dll)
> as a front end to VEE 5.
Beautiful! Well I guess in that case there's no need for this punky library
so I'll concentrate on getting rid of popup images that cover the VEE
window. Eventually
Incidentally we're supposed to be playing wild wind vortex roulette later
this afternoon so don't be surprised if the archive goes down for a while
during the storms.
-SHAWN-
window. Eventually
during the storms.
-SHAWN-
<DIV>I'm using a sequencer to run 26 tests in series. I want an option for operator who could select any test to start with. I used ExecTrans to control the test to start but the problem was it only run to that transaction and exit. Do you know any other ways or I have to create 26 sequencers, each has less one test.</DIV>
<DIV>Thank you for any help.</DIV>
<DIV> </DIV>
<DIV>Vnguyen</DIV>
