> So, I expect you'll need some kind of super cross-compiler
> that can recognize any MS or dotNet Classes and recompile.
Well yes a Windows emulator would be central to the whole thing. If it did
involve trying to modify VEE and recompiling then it wouldn't even be worth
investigating in the first place - Agilent are the only folks who could even
think about that.
Anyway, I'm sure not planning on walking down any of these roads! I've got
enough confusion with this C# thing.
Was it you that use C# regularly? Or was that Detlef? FWIW I've verified
proper operation of the VEEProcBool assembly both in C# itself and at the
debug level when used with VEE. I can't imagine why VEE isn't dealing with
it normally. Lots of .NET objects contain other .NET objects and they work
fine. Obviously I'm missing something very basic, but I just can't figure
out what it is.
-SHAWN-
think about that.
out what it is.
-SHAWN-
