Hi there.
I'm using Vee to interface to a bunch of COM objects. This works fine (usually), but some of the objects calls take rather long time to execute. Several minutes in fact. And in the mean time Vee locks up completely.
Is there a way to call a COM object that will allow other Vee threads to continue?
/Sren
/Sren
Unless the call is designed to be asynchronous not really. What you can do is have a surrogate dll hold your references and have it make calls on a different thread.
-SHAWN-
